Monitoring SQL Database - inside.
kyang
Re: Monitoring SQL Database - inside.
Post by kyang »
Thanks @mcapra!
Melanie123
Post by Melanie123 »
Thanks a lot mcapra, I have moved to the plugins proposed by you.
When I use the plugin "check_mssql_server.py" everything is good.
root@ubuntu:/usr/local/nagios/libexec# ./check_mssql_server.py -H x.x.x.x -U 'admin' -P 'pass' -p 1433 --time2connect
OK: Time to connect was 0.0201740264893s|time=0.0201740264893s;;;;
But now I have problem with plugin "check_mssql_database.py", typing the same data I get the error:
root@ubuntu:/usr/local/nagios/libexec# ./check_mssql_database.py -H x.x.x.x -U 'admin' -P 'pass' -p 1433 -T 'ah_Area'
(18456, "Login failed for user 'admin'.DB-Lib error message 20018, severity 14:
\nGeneral SQL Server error: Check messages from the SQL Server\
nDB-Lib error message 20002, severity 9:
\nAdaptive Server connection failed (x.x.x.x:1433)\n")
Any ideas?
Melanie123 wrote:Thanks a lot mcapra, I have moved to the plugins proposed by you.
Any ideas?
Are you sure the user that you are using has full rights for the database you are specifying?
Melanie123
Thanks for reply, scottwilkerson.
Yes, I'm sure. I finally gave up with the check_mssql_database.py plugin and came back to check_mssql.
And there is progress. :)
Now, I have a question about formatting the results of sql queries.
When I use:
./check_mssql -H x.x.x.x -U 'sa' -P xxx' -p 1433 -d database -q "SELECT ID_evt, name, evtTime, evtType, ID_tag FROM dbo.table WHERE name = 'alarm' AND ID_evt > 5157"
I have something like that:
OK: Query duration=0.004576 seconds. Query result=5158 Query result=Condition.Alarm Query result=2018-03-22 11:42:37 Query result=3 Query result=299 Query result=5161 Query result=Condition.Alarm Query result=2018-03-22 11:42:48 Query result=2 Query result=299 Query result=5162 Query result=Condition.Alarm Query result=2018-03-22 11:43:38 Query result=3 Query result=298 Query result=5163 Query result=Condition.Alarm Query result=2018-03-22 11:45:22 Query result=3 Query result=331
Where and how can I change the formatting so that the result of the plugin would be like:
OK: Query duration=0.004576 seconds. ID_evt =  5158, name = Condition.Alarm, evtTime = 2018-03-22 11:42:37, evtType = 3, ID_tag = 299
And "learn" for others: check x times if you are sure to enter good data from the SQL database. :)
Regards!
when using the query function of this plugin, it expects you are going to just retuen a singe value, your query is returning many
example
Example: check_mssql -H myserver -U myuser -P mypass -q "SELECT COUNT(*) FROM mytable" -W 2 -C 5
this would generate a warning if the count was more than 2 and critical if more than 5
There are no options for formatting the output with this plugin.
