Nagios Core Issue - Gaps in Graphs
davemcfadden
Re: Nagios Core Issue - Gaps in Graphs
Ive attached a zip file with the npcd log and the perfdata files that were copied to /tmp.
Dave.
Dave.
- service-perfdata.zip
- (160.05 KiB) Downloaded 101 times
The data looks good from what I can see but did you see any of the messages in the perfdata.log ? A message like this:
illegal attempt to update using time 0 when last update time is 1521482327 (minimum one second step)
is what I'm hoping to see in the logs and then check against the perfdata files.
davemcfadden
This is very odd. I left the modified process_perfdata.pl in place. I can see the files are still being copied to the /tmp, but the perfdata.log file looks like it was rotated overnight and is empty...
davemcfadden
I looked at the previous perfdata.log file - it looks like nothing else was written to the perfdata.log file after the new perl script was put in place.
- perfdata.log-20180321.gz
- (504 KiB) Downloaded 84 times
davemcfadden
I guess the new perl file is getting an error...
[03-22-2018 13:55:48] NPCD: Processing file service-perfdata.1521744942 with ID 140482463823616 - going to exec /usr/libexec/pnp4nagios/process_perfdata.pl -n --bulk /var/spool/pnp4nagios/service-perfdata.1521744942
[03-22-2018 13:55:48] NPCD: Processing file 'service-perfdata.1521744942'
[03-22-2018 13:55:48] NPCD: ERROR: Executed command exits with return code '5'
[03-22-2018 13:55:48] NPCD: ERROR: Command line was '/usr/libexec/pnp4nagios/process_perfdata.pl -n --bulk /var/spool/pnp4nagios/service-perfdata.1521744942'
[03-22-2018 13:55:50] NPCD: No more files to process... waiting for 15 seconds
davemcfadden
sorry for the multiple posts - I should have combined these.
Get this with running the checker now:
Dave.
root@usmke1hstnagvp01l:[a212356335]: perl verify_pnp_config.pl --mode bulk+npcd --config=/etc/nagios/nagios.cfg --pnpcfg=/etc/pnp4nagios
[INFO] ========== Starting Environment Checks ============
[INFO] My version is: verify_pnp_config-0.6.26-R.40
[INFO] Start Options: verify_pnp_config.pl --mode bulk+npcd --config=/etc/nagios/nagios.cfg --pnpcfg=/etc/pnp4nagios
[INFO] Reading /etc/nagios/nagios.cfg
[OK ] Running product is 'nagios'
[OK ] object_cache_file is defined
[OK ] object_cache_file=/var/spool/nagios/objects.cache
[INFO] Reading /var/spool/nagios/objects.cache
[OK ] resource_file is defined
[OK ] resource_file=/etc/nagios/private/resource.cfg
[INFO] Reading /etc/nagios/private/resource.cfg
[INFO] Reading /etc/pnp4nagios/process_perfdata.cfg
[INFO] Reading /etc/pnp4nagios/pnp4nagios_release
[OK ] Found PNP4Nagios version "0.6.25"
[OK ] ./configure Options '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--program-prefix=' '--disable-dependency-tracking' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/var/lib' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--bindir=/usr/sbin' '--libexecdir=/usr/libexec/pnp4nagios' '--sysconfdir=/etc/pnp4nagios' '--localstatedir=/var/log/pnp4nagios' '--datadir=/usr/share/nagios/html/pnp4nagios' '--datarootdir=/usr/share/nagios/html/pnp4nagios' '--with-perfdata-dir=/var/lib/pnp4nagios' '--with-perfdata-spool-dir=/var/spool/pnp4nagios' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' 'LDFLAGS=-Wl,-z,relro '
[OK ] Effective User is 'nagios'
[OK ] User nagios exists with ID '993'
[OK ] Effective group is 'nagios'
[OK ] Group nagios exists with ID '990'
[INFO] ========== Checking Bulk Mode + NPCD Config ============
[OK ] process_performance_data is 1 compared with '/1/'
[OK ] service_perfdata_file is defined
[OK ] service_perfdata_file=/var/log/pnp4nagios/stats/service-perfdata
[OK ] service_perfdata_file_template is defined
[OK ] service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$
[OK ] PERFDATA template looks good
[OK ] service_perfdata_file_mode is defined
[OK ] service_perfdata_file_mode=a
[OK ] service_perfdata_file_processing_interval is defined
[OK ] service_perfdata_file_processing_interval=15
[OK ] service_perfdata_file_processing_command is defined
[OK ] service_perfdata_file_processing_command=process-service-perfdata-file
[OK ] host_perfdata_file is defined
[OK ] host_perfdata_file=/var/log/pnp4nagios/stats/host-perfdata
[OK ] host_perfdata_file_template is defined
[OK ] host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$
[OK ] host_perfdata_file_mode is defined
[OK ] host_perfdata_file_mode=a
[OK ] host_perfdata_file_processing_interval is defined
[OK ] host_perfdata_file_processing_interval=15
[OK ] host_perfdata_file_processing_command is defined
[OK ] host_perfdata_file_processing_command=process-host-perfdata-file
[INFO] Nagios config looks good so far
[INFO] ========== Checking config values ============
[OK ] npcd daemon is running
[OK ] /etc/pnp4nagios/npcd.cfg is used by npcd and readable
[INFO] Reading /etc/pnp4nagios/npcd.cfg
[OK ] perfdata_spool_dir is defined
[OK ] perfdata_spool_dir=/var/spool/pnp4nagios
[CRIT] 10087 files found in /var/spool/pnp4nagios
[HINT] Something went wrong here!
service_perfdata_file_processing_command at verify_pnp_config.pl line 462.
[OK ] Command process-service-perfdata-file is defined
[OK ] '/bin/mv /var/log/pnp4nagios/stats/service-perfdata /var/spool/pnp4nagios/service-perfdata.$TIMET$'
[OK ] Command looks good
host_perfdata_file_processing_command at verify_pnp_config.pl line 462.
[OK ] Command process-host-perfdata-file is defined
[OK ] '/bin/mv /var/log/pnp4nagios/stats/host-perfdata /var/spool/pnp4nagios/host-perfdata.$TIMET$'
[OK ] Script /usr/libexec/pnp4nagios/process_perfdata.pl is executable
[INFO] ========== Starting global checks ============
[OK ] status_file is defined
[OK ] status_file=/var/spool/nagios/status.dat
[INFO] host_query =
[INFO] service_query =
[INFO] Reading /var/spool/nagios/status.dat
[INFO] ==== Starting rrdtool checks ====
[OK ] RRDTOOL is defined
[OK ] RRDTOOL=/usr/bin/rrdtool
[OK ] /usr/bin/rrdtool is executable
[OK ] RRDtool 1.4.8 Copyright 1997-2013 by Tobias Oetiker <[email protected]>
[OK ] USE_RRDs is defined
[OK ] USE_RRDs=1
[OK ] Perl RRDs modules are loadable
[INFO] ==== Starting directory checks ====
[OK ] RRDPATH is defined
[OK ] RRDPATH=/var/lib/pnp4nagios
[OK ] Perfdata directory '/var/lib/pnp4nagios' exists
[WARN] 252 hosts/services are not providing performance data
[WARN] 'process_perf_data 1' is set for 166 hosts/services which are not providing performance data!
[WARN] 'process_perf_data 0' is set for 87 of your hosts/services
[OK ] 'process_perf_data 1' is set for 382 of your hosts/services
[WARN] Logging is enabled in process_perfdata.cfg. This will reduce the overall performance of PNP4Nagios
[INFO] ==== System sizing ====
[OK ] 468 hosts/service objects defined
[INFO] ==== Check statistics ====
[CRIT] Warning: 4, Critical: 1
[CRIT] Checks finished...Dave.
Reason: Please use [code][/code] tags around terminal output
davemcfadden
OK there was some customization log and config files in the original perl script, so I have made those changes in the new one and now log files are being generated. I'll upload the logs and update service files in a few.
Many thanks,
Dave.
Many thanks,
Dave.
davemcfadden
Attached is the host and performance data, and the perfdata.log.
Many thanks,
Dave.
Many thanks,
Dave.
- host-perfdata.zip
- (35.56 KiB) Downloaded 92 times
Thanks for data and fixing the script to get it! Unfortunately it looks good but we've at least eliminated some possibilities.
The errors seen a thrown when the rrdtool command is run and tries to update runtime rrd files in /var/lib/pnp4nagios/.pnp-internal/. What version of the rrdtool file is installed? When you say you removed the rrd file and let them be recreated again, were you referring to the ones in /var/lib/pnp4nagios/.pnp-internal/ ? If not, try removing these and let them be created.
davemcfadden
Thanks.
I have removed .rrd files for individual servers, but not in that directory.
I have removed them.
Interesting enough, this is from the .xml files in the directory:
runtime.xml.303: <TXT>creating '/var/lib/pnp4nagios/.pnp-internal/runtime_create.rrd': Permission denied</TXT>
runtime.xml.304: <TXT>creating '/var/lib/pnp4nagios/.pnp-internal/runtime_create.rrd': Permission denied</TXT>
runtime.xml.3649: <TXT>creating '/var/lib/pnp4nagios/.pnp-internal/runtime_create.rrd': Permission denied</TXT>
runtime.xml.722: <TXT>creating '/var/lib/pnp4nagios/.pnp-internal/runtime_create.rrd': Permission denied</TXT>
runtime.xml.725: <TXT>start time: unparsable time: DATATYPE::HOSTPERFDATA</TXT>
So hopefully we are getting closer.
Many thanks,
Dave.
Thanks.
Many thanks,
Dave.
