Nagios Notifications not sending
kwhogster
Re: Nagios Notifications not sending
Post by kwhogster »
Guys
I now can send email internally and externally via command line using mailx
Setup the command in Nagios with the -r
All looks good.
Problem is I am still not getting notified by either text or email when I get an alarm on Nagios.
I checked the mail queue and I have no new messages queued up. just a couple of old ones during testing still there,
What else can I check? Note I recently setup escalations
Thoughts?
tacolover101
Post by tacolover101 »
can you please show us your mailx commands, and also your objects.cache? (/usr/local/nagios/var/objects.cache)
what contact is not receiving notifications properly, and for what host & service?
that should be enough to tack it down.
kwhogster
Post by kwhogster »
This command line works
echo "test text2" | mailx -s testtext -r [email protected] [email protected]
I am now getting email alerts but randomly not all the alerts are sending notifications.
I and not getting and text alerts at all I set up a separate group for them maybe that's the problem?
define contact{
        contact_name                    support
        alias                           Network Support
        service_notification_period     24x7
        host_notification_period        24x7
        service_notification_options    c,r
        host_notification_options       d,r
        service_notification_commands   notify-service-by-email
        host_notification_commands      notify-host-by-email
        email                           [email protected]
define contact{
        contact_name                    text305
define contact{
        contact_name                    text551
define contactgroup{
        contactgroup_name       admins
        alias                   Nagios Administrators
        members       nagiosadmin, support, iosapp
        contactgroup_name       textit
        alias                   Nagios Admins
        members                 text305, text551
contact group admins works sometimes. group textit does not at all
My escalations config
define serviceescalation{
        hostgroup_name          windows-servers,windows-servers-vm,linux-servers
        service_description     *
        first_notification      24
        last_notification       48
        notification_interval   360
        contact_groups          admins,textit
        hostgroup_name          Windows-Desktops,windows-desktops-vm
define hostescalation{
        first_notification      5
        last_notification       8
        notification_interval   60
        last_notification       8
        hostgroup_name          nas-storage,network-printers,switches
        last_notification       8
I attached my objects.cache file as a txt file hope this helps
On my checks for the computers some have notification_interval set to 0 and others do not have that setting ????
hope this helps
objects-cache.txt
objects.cache
(841.82 KiB) Downloaded 553 times
text305 is only part of the textit contact group, when I searched your objects.cached, textit is only attached to escalations most of which have a first_notification of 24
This means 24 regular notifications have to go out before this escalation triggers.
For everything where notification_interval = 0 this will never happen, because these will not renotify
kwhogster
Post by kwhogster »
Should I add contact_groups admins, textit to each of my hosts ?
If I do that I do not need to add contact_groups to all my services correct?
I am not sure why I made the notification_interval = 0 I will change them to the default 60
Thoughts
Update I now remember why I changed the notification_interval to 0 I have a check_Interval = 1440 or 10080 or 1 or 360 etc
How would I setup notification_internavals with values like that?
kwhogster wrote:Should I add contact_groups admins, textit to each of my hosts ?
that would be correct, except, if you manually add a contact to a service you would also want to add the contact group because it would break the host-> service implied inheritance.
kwhogster wrote: Update I now remember why I changed the notification_interval to 0 I have a check_Interval = 1440 or 10080 or 1 or 360 etc
Not sure of your desired affect, but setting notification_interval to 0 disables re-notifications. You would want to set this value to the frequency you want to be re-notified
kwhogster
Post by kwhogster »
I get this when I change the notification_interval to the default value of 60
Warning: Service 'NSClient++ Version' on host 'TGKW001' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
host_name TGKW001
service_description NSClient++ Version
servicegroups nsclients
check_interval 10080
check_command check_nt!CLIENTVERSION
If I set it to 0 no warnings. I only need to check this once a week as 10080 means.
If I make the value the same as the check_interval 10080 then it does not give a warning either
But what does that mean? Will I only get a notification once a week also?
Has any one set the check_interval to a higher value than the default?
kwhogster wrote:Warning: Service 'NSClient++ Version' on host 'TGKW001' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
this is just a warning, AKA a reminder, not to expect notifications more frequently than your check interval
kwhogster wrote:If I make the value the same as the check_interval 10080 then it does not give a warning either
It will act the same way as if the notification_interval was less than the check_interval UNLESS the notification_interval is set to 0 which is special and disables re-notifications.
kwhogster wrote:Will I only get a notification once a week also?
yes.
kwhogster wrote:Has any one set the check_interval to a higher value than the default?
yes all the time, you just need to know that you will never get a notification more frequently than you are allowing the check to run (check_interval)
kwhogster
Post by kwhogster »
Cool
I will go thru all my checks
Will post results
Off to shovel snow now
let us know if we can be of further assistance
