NDOutils instalation problem
Re: NDOutils instalation problem
I have also been looking into using nagiosgraph. the pnp4nagios you suggested is not compatible with Nagios 4.x
nd02db.debug.txt- (57.4 KiB) Downloaded 237 times
That isn't true, just the sync mode isn't...sstapels wrote: the pnp4nagios you suggested is not compatible with Nagios 4.x
here's a guide
https://arkit.co.in/pnp4nagios-installa ... iguration/
