XI authentication denied to Fusion
TBT
Re: XI authentication denied to Fusion
Post by TBT »
cnorell wrote:Hey TBT,
What versions of Fusion and XI are you currently running?
I am attempting to replicate your issue with testing the Fusion settings, with no luck on the latest releases.
XI 5.4.8 and Fusion 4.1.3.
We'll be upgrading XI to 5.4.13 in the coming weeks.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
cnorell
Developer
Post by cnorell »
TBT,
Thank you for your reply.
I am still unable to replicate the Fusion settings issue. Perhaps I am misunderstanding what is happening.
The way I understand it, the Fusekey check is passing (green check mark), however the username check is failing (red exclamation point). Is that correct, or are you seeing the red icon in a different location within Fusion?
TBT
Post by TBT »
cnorell wrote:TBT,
Correct. The username test fails, yet Fusion indicates "Everything is Ok!" (another green check mark) in the header menu. Network elements from the XI server in question also appear in Fusion.
cnorell
Developer
Post by cnorell »
Alright.
Is the username check failing on all XI servers you try to fuse, or one server in particular?
Also, is the XI server you are trying to fuse using SSL?
