thank you. Maybe someone who developed this plugin can cause which changes are made between these 2 versions.
For now I´am running on 2.1.4 which works fine.
check_http > CRITICAL - Cannot make SSL connection.
Re: check_http > CRITICAL - Cannot make SSL connection.
As a FYI the changes are listed here
https://github.com/nagios-plugins/nagio ... aster/NEWS
that´s good, but I´am not a developer so I don´t understand changes in source code.
I can make any test what you want or need but I can´t to identify which changes between 2.1.4 and 2.2.1 can make this issue.
Regards,
Petr
Regards,
Petr
As I had mentioned earlier, I couldn't find any either, and the plugin works on all SSL servers I have tried.
today I tried to download v 2.2.0 which is between 2.1.4 and 2.2.1 and this version has the same issue.
If it is possible to create a case that can be replicated every time, you can open that as an issue with the plugins project
https://github.com/nagios-plugins/nagios-plugins/issues
Just be sure to give as much information about the server you cannot connect to as possible, because as of yet I am unable to replicate the issue
