which Nortel and firewall device wizard
Re: which Nortel and firewall device wizard
OK, let us know if you have any further questions.
ganeshkagde
Hi @tgriep,
I am getting error while saving as command. PFA snap for the snap.
Can you run the following command on the XI server as root and post the output?
It should show the list of commands that are in the MYSQL database and then we can check it for any duplicates.
echo 'select * from tbl_command;' |mysql -t -u root -pnagiosxi nagiosqlBe sure to check out our Knowledgebase for helpful articles and solutions!
ganeshkagde
PFA txt file of commands output.
The last entry in the cmd.txt file shows that the check_nwc_health command is defined already.
Are you trying to create a copy of that command but are keeping the Command Name the same?
If so, it has to have a unique name so change it and it should allow you save the copy.
ganeshkagde
Hi Team,
from attached snap Which wizard should i use to enrolled Nortel and firewall device.
If you want to use the check_nwc_health plugin, there is not a Wizard for it so you will have to create a Service Check manually.
The following link are instructions on how to do that.
https://support.nagios.com/kb/article/n ... t-539.html
