Monitoring Docker containers
jankogaga
Re: Monitoring JMX
Post by jankogaga »
I have followed https://support.nagios.com/kb/article.php?id=515.
I run Centos 7 in a docker container
when trying
make install-init
I get:
No init file to install
make: *** [install-init] Error 1
I think that is related to the docker implementation.
Re: Monitoring JMX
The make install-init is looking for the following script
rh-upstart-init
in the startup folder.
Does it exist and does the rh-upstart-init.in file exist in that folder?
Can you post the config.log file from the nrpe source folder?
jankogaga
Re: Monitoring JMX
Post by jankogaga »
/tmp/nrpe-nrpe-3.2.1/startup/rh-upstart-init.in does exist.
Here is attached /tmp/nrpe-nrpe-3.2.1/config.log
config.log
(62.84 KiB) Downloaded 439 times
Re: Monitoring JMX
Actually it should be just
However, pardon my ignorance, but can you run traditional services now in a docker container? I ask because last I worked with them a few years ago you could not.
jankogaga
Re: Monitoring JMX
Post by jankogaga »
Both, /tmp/nrpe-nrpe-3.2.1/startup/rh-upstart-init and /tmp/nrpe-nrpe-3.2.1/startup/rh-upstart-init.in exist.
I tried now starting "make install-init" from startup folder:
[root@test-difin startup]# make install-init
make: *** No rule to make target `install-init'.  Stop.
Regarding docker container:
In Dockerfile you can add:
COPY            supervisord.conf /etc/supervisord.conf
ENTRYPOINT      ["/usr/bin/supervisord"]
In supervisord.conf define what services-daemon will be started.
E.g. for nrpe deamon I would add (maybe I am wrong):
[program:nrpe]
command=/usr/sbin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d
Re: Monitoring JMX
There is no "init" file for docker then, the configure script can't detect you are in docker, you would have to skip that part and add the supervisord item
But I believe the command is as follows
[program:nrpe]
command=/usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d
jankogaga
Re: Monitoring JMX
Post by jankogaga »
Thanks scottwilkerson.
This command does the trick.
Now, I get:
[root@test-difin /]# netstat -anp |grep 5666
tcp        0      0 0.0.0.0:5666            0.0.0.0:*               LISTEN      -
tcp6       0      0 :::5666                 :::*                    LISTEN      -
but still on the Nagios Core server:
/usr/local/nagios/libexec/check_nrpe -H 10.30.30.33
connect to address 10.30.30.33 port 5666: Connection refused
connect to host 10.30.30.33 port 5666: Connection refused
Re: Monitoring JMX
Well we are getting somewhere, again, my docker is VERY rusty, but don't you have to map ports to expose them to the outside world?
jankogaga
Re: Monitoring JMX
Post by jankogaga »
The port mapping is already done:
-p 10.30.30.33:5666:5666
firewall rules on docker'host is set:
-A PREROUTING -i eth0 -p tcp --dport 5666 -j DNAT --to-destination 10.30.30.33
-A PREROUTING -i eth0 -p udp --dport 5666 -j DNAT --to-destination 10.30.30.33
-A ufw-user-input -p tcp --dport 5666 -j ACCEPT
-A ufw-user-input -p udp --dport 5666 -j ACCEPT
But still can't connect to it from Nagioc Core
Re: Monitoring JMX
The
Connection refused
is not coming form NRPE, it is at a different layer, like something is blocking the port e.g. firewall, or NRPE isn't actually bound to the port which doesn't seem to be the case because of your netstat output
