Nagios core 4.3.4 LDAP and authorization
Re: Nagios core 4.3.4 LDAP and authorization
Here is the official documentation
https://assets.nagios.com/downloads/nag ... iauth.html
https://assets.nagios.com/downloads/nag ... _all_hosts
I guess in that you are correct I do not see in the documentation the ability to wildcard with a * so this:
authorized_for_all_services=*
authorized_for_all_hosts=*
Would for all practical purposed equal
emi65
Post by emi65 »
Hi Scott
WITH LDAP authentication
if I set in cgi.cg
and I set in the host1.cfg contact user1
.... the user1 see only the host1
WITH PASSWD authentication
if I set in cgi.cg
so behavior of cgi.cfg is different when I use LDAP then PASSWD
(the * (star) is interpreted in different way)
Is this a bug ?
Thank
Emilio
kyang
Post by kyang »
if I set in cgi.cg
if I set in cgi.cg
So either option allows user1 to view only host1?
I'll have to set up an LDAP server with Core to see if I'm seeing the same thing.
emi65
Post by emi65 »
Yes you are in rigth
In both case user1 see the host 1
but the difference is big because the behaviour of cgi.cfg is difference
I have to set in cgi.cg
while WITH PASSWD authentication I have to set
This create another difference
WITH LDAP the user2 can NOT see any hosts
WITH PASSWD the user2 can see ALL hosts
The * (star) in cgi.cfg has a differente behaviour when I use LDAP then when I use PASSWD
I like to get this situation
Use LDAP
show one or limited number of hosts to user1
show ALL hosts for all other users (user1,user2,user3 ..... user999)
set in cgi.cfg
Does it possible to get this behaviour ?
Regards
Emilio
kyang
Post by kyang »
Thanks for the explanation,
Please understand that I am currently trying this integration with Core when I have time.
I'll be using this information to see if I can recreate it on my end.
emi65
Post by emi65 »
Hi Kyang
Many thanks for all your help
If you will find a solution , please , updates this 3rd
Thanks again
Emilio
kyang
Post by kyang »
Could you attach your full /etc/httpd/conf.d/nagios.conf file?
Also, just to double check. You are logging in as an LDAP user & not a Core user?
Thanks!
emi65
Post by emi65 »
here the file
ScriptAlias /nagios/cgi-bin "/usr/lib64/nagios/cgi-bin/"
<Directory "/usr/lib64/nagios/cgi-bin/">
   Options ExecCGI
   AllowOverride None
        Order allow,deny
        Allow from all
    AuthType Basic
    AuthBasicProvider ldap
    AuthName "LDAP Authentication"
    # AuthzLDAPAuthoritative off
    AuthLDAPURL ldap://ldap-sedi.sedi-direzioni.group:389/DC=sedi-direzioni,DC=group?sAMAccountName?sub?(objectClass=person)
    AuthLDAPBindDN "CN=GS01068 FRINI EMILIO,OU=Utenti,OU=XXXXXX,OU=XXXXXX,OU=DIREZIONEGS,DC=sedi-direzioni,DC=group"
    AuthLDAPBindPassword "XXXXX"
    AuthLDAPGroupAttributeIsDN on
    AuthLDAPGroupAttribute member
    #Require valid-user
    Require ldap-group cn=ggUtentiDire3532,OU=DIRE3532,OU=DIRE3437,OU=DIREZIONEGS,DC=sedi-direzioni,DC=group
    Require ldap-group cn=ggUtentiDire8214,OU=DIRE8214,OU=DIRE3375,OU=DIREZIONEGS,DC=sedi-direzioni,DC=group
</Directory>
Alias /nagios "/usr/share/nagios/html"
<Directory "/usr/share/nagios/html">
   Options None
   AllowOverride None
        Order allow,deny
        Allow from all
    AuthType Basic
    AuthLDAPBindDN "CN=GS01068 FRINI EMILIO,OU=Utenti,OU=XXXXX,OU=XXXX,OU=DIREZIONEGS,DC=sedi-direzioni,DC=group"
    AuthLDAPBindPassword "XXXXXX"
    #Require valid-user
</Directory>
Last edited by scottwilkerson on Wed Jun 20, 2018 12:57 pm, edited 1 time in total.
Reason: wrap in code tags
emi65 wrote:Yes you are in rigth
Use LDAP
set in cgi.cfg
Regards
Emilio
I am not sure why the behavior would be different between using basic auth or LDAP, the username should be the same to the backend either way.
That said you can feel free to investigate it further and if you find the Nagios Core code needs patching, the developers of the free open source Nagios Core would welcome the contribution
https://github.com/NagiosEnterprises/nagioscore
