--ssl=VERSION[+]
Connect via SSL. Port defaults to 443. VERSION is optional, and prevents
auto-negotiation (2 = SSLv2, 3 = SSLv3, 1 = TLSv1, 1.1 = TLSv1.1,
1.2 = TLSv1.2). With a '+' suffix, newer versions are also accepted.
Try that as well in your command.
The --sni option is needed in cases where the destination hosts multiple domains or may require it. Run the check with this option and if it still fails, please PM a packet capture that contains an attempt to run it:
yum -y install tcpdump
tcpdump -s 0 -i any port 443 -w output.pcap
Let it run just long enough to reproduce the error and then use CTRL+C to stop it. PM me the output.pcap and I can take a closer look or you can use Wireshark to review it yourself.
