multiple snapshots_maintenance jobs running
Re: multiple snapshots_maintenance jobs running
This is interesting although I don't suspect it is the issue, it is weird that it happened at the time that you also say this weird activity started.
Can you look in your list of snapshots and see if there is a snapshot created for last Saturday?
CBoekhuis
Post by CBoekhuis »
Only one snapshot was created
I believe we found a bug in 2.0.3
Would you be willing to test a fix?
Unzip the attached and upload it to replace the following file
/var/www/html/nagioslogserver/application/models/Cmdsubsys.php
We believe this should stop the duplicate snapshots
Cmdsubsys.zip
We were able to replicate this issue in-house and confirm the above fixed the issue.
CBoekhuis
Post by CBoekhuis »
That's good news! I'll install the fix first thing on Monday. Thank you and I'll update the results as soon as I've run a test.
CBoekhuis
Post by CBoekhuis »
The new Cmdsubsys.php fixes the issue. The high load is gone, it doesn't take hours to run and I get 1 snapshot.
Thank you for the fix!
Excellent! Marking Resolved.
