how to setup file system usage
donnyforbes
Re: how to setup file system usage
Post by donnyforbes »
npolovenko wrote:@donnyforbes, Just noticed that your command is repeating 2 times:
[nagios@nag ~]$ /usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -c check_folder_size -a "-f /var -s g -w 60 -c 80"
The command needs to look like this:
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -c check_folder_size -a "-f /var -s g -w 60 -c 80"
Where 192.168.1.12 is the IP address of the remote server that has the /var folder.
And yes, the command needs to be executed from the Nagios XI server's console.
If you get the SSL handshake error again, please refer to this tutorial to troubleshoot the problem:
https://support.nagios.com/kb/article/n ... e-615.html
Ran again and got this ...
[nagios@nag ~]$ /usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -c check_folder_size -a "-f /var -s g -w 60 -c 80"
NRPE: Command 'check_folder_size' not defined
different error did I do something wrong?
npolovenko
Post by npolovenko »
@donnyforbes, I apologize, our command was:
command[check_disk_new]=/usr/local/nagios/libexec/check_folder_size $ARG1$
So please rerun the command with the correct name:
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c check_disk_new -a "-f /var -s g -w 60 -c 80"
donnyforbes
npolovenko wrote:@donnyforbes, I apologize, our command was:
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -c check_disk_new -a "-f /var -s g -w 60 -c 80"
Do you need me to add this in the nrpe.cfg file on the nagios server
then run this from the XI
npolovenko
@donnyforbes
On the remote nrpe server. In /usr/local/nagios/etc/nrpe.cfg file, to the section with all the other commands.
donnyforbes
so on the nagios server add this?
On
donnyforbes wrote:so on the nagios server add this?
No, on the remote server.
donnyforbes
scottwilkerson wrote:On
Here is what I did. On the remote server I added the following
then ran the following command below.
[nagios@nag ~]$
 /usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -c check_disk_new -a "-f /var -s g -w 60 -c 80"
NRPE: Unable to read output
output was a little different ...
npolovenko
@donnyforbes, Now your command is repeating 3 times.
Here is the correct command:
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -t 30 -c check_disk_new -a "-f /var -s g -w 60 -c 80"
*Where 192.168.1.12 is the IP address of the remote server.
donnyforbes
npolovenko wrote:@donnyforbes, Now your command is repeating 3 times.
yes .12 is the remote server where I add this to.
Just ran again and got this.
[nagios@nag ~]$
/usr/local/nagios/libexec/check_nrpe -H 192.168.1.186 -t 30 -c /usr/local/nagios/libexec/check_nrpe -H 192.168.1.12 -t 30 -c check_disk_new -a "-f /var -s g -w 60 -c 80"
npolovenko
@donnyforbes
[nagios@nag ~]$
This is not the command that I suggested. The command was:
