Ping check is failing
smapple
Re: Ping check is failing
Post by smapple »
It worked! Thanks a ton!
Also one last question. I do not see check_lvm in my plugins. Can you share the procedure to get this and install?
I am glad I could help! :)
As far as the "check_lvm" plugin goes, it is not shipped by default with Nagios XI. It seems like this is a 3rd party plugin, found on the Nagios Exchange here:
https://exchange.nagios.org/directory/P ... vm/details
You could download it to your Nagios XI server, test it from the command line, and add a command and a service by following the steps, outlined in the document below:
Thank you!
smapple
Post by smapple »
Thank you!!
I will download and test it. Thanks!
Great! I will be closing this topic now. If you have any more questions/issue, please start a new thread. Thank you!
