XI check_oracle_health plugin tablespace errors
[email protected]
Re: XI check_oracle_health plugin tablespace errors
Post by [email protected] »
@comeonyoyo
Should the --mode connection-time mode that Scott suggests to check work, please also check --mode list-tablespacese.
If the last one fails then double check preparation steps at https://labs.consol.de/nagios/check_ora ... e-database. Especially these:
grant select on SYS.DBA_DATA_FILES to nagios;
grant select on SYS.DBA_FREE_SPACE to nagios;
I've seen situations where either SYS.DBA* or V$INSTANCE grants were missing resulting in the error you reported. By the way.. your output proves that SELECT version FROM v$instance runs OK. So you can focus on SYS.DBA_DATA_FILES and SYS.DBA_FREE_SPACE.
comeonyoyo
Post by comeonyoyo »
here is the result of test, and I will check with the owner of the database
connection-time (looks ok)
list-tablespace (the same error)
Thank you ~
Yes I would definitely check to verify the items mentioned above with the DB owner.
