This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
Post
by scottwilkerson »
meston.nu wrote:Those commands completed without error.
Good, run
Then lets try to proceed with the upgrade
meston.nu
Post
by meston.nu »
no dice.
Post
by scottwilkerson »
Please run the following and return the results
- Bugs find me
Post
by lmiltchev »
Also, run the following command and show the output.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
meston.nu
Post
by meston.nu »
Post
by scottwilkerson »
Lets edit /etc/yum.repos.d/epel.repo and uncomment baseurl and comment mirrorlist
like so
[epel]
name=Extra Packages for Enterprise Linux 6 - $basearch
baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
#mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=$basearch
failovermethod=priority
enabled=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
[epel-debuginfo]
name=Extra Packages for Enterprise Linux 6 - $basearch - Debug
baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch/debug
#mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-debug-6&arch=$basearch
enabled=0
gpgcheck=1
[epel-source]
name=Extra Packages for Enterprise Linux 6 - $basearch - Source
baseurl=http://download.fedoraproject.org/pub/epel/6/SRPMS
#mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-source-6&arch=$basearch
enabled=0
gpgcheck=1
then try
if that works, proceed
meston.nu
Post
by meston.nu »
I updated the file as instructed and these were the results.
Post
by scottwilkerson »
If you are getting that error then you didn't comment all the mirrorlist lines
grep mirrorlist -R /etc/yum.repos.d|grep fedora
meston.nu
Post
by meston.nu »
I commented out the file you told me, but apparently there was another (see below).
After commenting those lines, I ran yum update and this was the result.
Post
by scottwilkerson »
Are you sure this server isn't behind a proxy?
