Session times out after about 30 seconds
dkowalski
Re: Session times out after about 30 seconds
Post by dkowalski »
So your last post... thats the best answer you have?
Ok guys Im getting pretty frustrated! This is a nagios VM (R1.9) Upgraded to 2.0 this should not have system configuration problems out of the box. It bieng a Virtual Machine should be like the Nagios god himself came to my office and installed it. it should just work! I dont have the time or patients to debug your software.
I have set and unset the EnableSendFile directive with no effect and yes I restarted httpd servies each time.
I can understand your frustration however we haven't seen many of these issues whith any others using these same VM's.
Would it be possible to have you try a new VM, because for some reason the one you are working with is having many problems that we cannot replicate.
The link to our current VM is
http://assets.nagios.com/downloads/nagi ... vmware.zip
