Services stuck in soft state - no notifications
Re: Services stuck in soft state - no notifications
Please let us know when you have had a chance to upgrade, and whether this fixed your issue.
I believe I found the cause in Core and is fixed in the maint branch on Github
https://github.com/NagiosEnterprises/na ... ee/maint​​
wget https://github.com/NagiosEnterprises/nagioscore/archive/maint.tar.gz​
tar xzf maint.tar.gz​
cd nagioscore-maint​
configureflags="--with-command-group=​nagcmd"
if [ ! `command -v systemctl` ] || [ -f /etc/init.d/nagios ]; then
    configureflags="--with-init-type=sysv $configureflags"
fi
./configure "$configureflags"​
make -j 2 all​
make install​
service nagios restart
After this once the services stuck in soft state go to OK state either naturally, or by stopping nagios and removing retention.dat they should no longer get stuck
