I don't have a script to change all of these but let's try just a couple of them first to see if maybe this is the right track. Since teh inital error mentioned bundler, edit the source lines in:
subcomponents/logstash/logstash-2.4.1/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/templates/Gemfile
subcomponents/logstash/logstash-2.4.1/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/templates/newgem/Gemfile.tt
to use:
https://rubygems.org
Upgrade fail because of ruby SSL error
Re: Upgrade fail because of ruby SSL error
Cpt.Ackbar
I am going to reinstall these log servers from scratch. I am currently having another issue with logstash keeps falling. I will let you know in case issue will persist.
Thanks for your support so far,
Martin
Martin
Thanks for the update. We'll be here if needed.
