Hi Team,
Thanks for giving reply. I have observed the audit logs as below.
Find the attachment and give reply for my question
1) User some X person has done changes in service and represent that ID=16 and when we see cmd_type list ID=16 represent as Disabled host service check.
correct me if my assumption is wrong
How to know that X person has changed host service check on which host and which service? This complete details we are not able to see in audit log.
NagiosXI CCM log
Re: NagiosXI CCM log
That is correct, that the command ID of 16 would be CMD_DISABLE_HOST_SVC_CHECKS. From the looks of it, the audit log does not have host/service details for these particular logs. It looks like you can see the info for the command in the very next log line:
I am going to add this to the list for future releases, since this makes sense to give details about the command submitted.
Hi Team,
thanks for reply but we are not able see for global configuration. if anybody change in global configuration for that we are not able to see.
For Ex: user has changed in performance setting in Admin --> performance setting --> database or etc.
Yes you are correct, the audit log does not log everything. It's on the list for things to be improved upon in future feature releases.
