Notification count never resets -> escalations don't trigger
Re: Notification count never resets -> escalations don't tri
I believe I found the cause in Core and is fixed in the maint branch on Github
https://github.com/NagiosEnterprises/na ... ee/maint​​
wget https://github.com/NagiosEnterprises/nagioscore/archive/maint.tar.gz​
tar xzf maint.tar.gz​
cd nagioscore-maint​
configureflags="--with-command-group=​nagcmd"
if [ ! `command -v systemctl` ] || [ -f /etc/init.d/nagios ]; then
    configureflags="--with-init-type=sysv $configureflags"
fi
./configure "$configureflags"​
make -j 2 all​
make install​
service nagios restart
After this once the services stuck in soft state go to OK state either naturally, or by stopping nagios and removing retention.dat they should no longer get stuck
gornm565
Post by gornm565 »
When would this fix be released approximately?
gornm565 wrote:When would this fix be released approximately?
It is in final testing, could be this week, or next for Core release.
a7ger
Post by a7ger »
This has been fixed with version 4.4.2
a7ger wrote:This has been fixed with version 4.4.2
Great! Thanks for verifying!
Locking Thread
