Nagios XI 5.5.0 upgrade 5.5.1 failed
jacek
Re: Nagios XI 5.5.0 upgrade 5.5.1 failed
Post by jacek »
It is not upgraded:
cat /usr/local/nagiosxi/html/includes/components/proxy/proxy.inc.php | grep VERSION
        COMPONENT_VERSION => '1.1.3',
cmdsubsys.log:
PROCESSING COMMAND ID 5151...
PROCESS COMMAND: CMD=1131, DATA=a:1:{i:0;a:2:{s:4:"name";s:5:"proxy";s:3:"url";s:69:"https://assets.nagios.com/downloads/nagiosxi/components/xi5/proxy.zip";}}
AUTO UPGRADING COMPONENTSCMD DATA: Array
    [0] => Array
            [name] => proxy
            [url] => https://assets.nagios.com/downloads/nagiosxi/components/xi5/proxy.zip
TMPNAME: oGZQQ
Archive:  proxy.zip
2d89ed8ec5333353c903d9578ea2e4f7478f4f59
   creating: proxy/
  inflating: proxy/CHANGES.txt
  inflating: proxy/proxy.inc.php
  inflating: proxy/proxyconfig.php
  inflating: proxy/sanity.sh
CMDLINE=. /usr/local/nagiosxi/var/xi-sys.cfg && chmod -R 755 /usr/local/nagiosxi/tmp/oGZQQ/proxy && chown -R $nagiosuser:$nagiosgroup /usr/local/nagiosxi/tmp/oGZQQ/proxy && cp -rf /usr/local/nagiosxi/tmp/oGZQQ/proxy /usr/local/nagiosxi/html/includes/components/ && rm -rf /usr/local/nagiosxi/tmp/oGZQQ
OUTPUT=
RETURNCODE=0
RUNNING POST FUNCTION CALL: install_component
INSTALLING COMPONENT: proxy
CHECKING FOR INSTALL SCRIPT /usr/local/nagiosxi/html/includes/components/proxy/install.sh
POST FUNCTION CALL RETURNCODE=0
jomann
Development Lead
Post by jomann »
It looks like our component versions script was not updating properly. It should now be fixed. Run the check for updates again to force the download of the new xml file and now it should install the new components.
jacek
Post by jacek »
It worked now, perfec, thank You!
Great! Is it safe to lock this topic then?
jacek
Post by jacek »
Sure :-)
