There was a bug found that started in 5.5.0
unzip the attachment
replace /usr/local/nagiosxi/cron/deadpool.php with it's contents
Deadpool Issues
Re: Deadpool Issues
Re: Deadpool Issues
That did the Trick.
Thank you for the assistance!
Matter solved
Matter solved
HOMO SUM HUMANI NIHIL A ME ALIENUM PUTO
Re: Deadpool Issues
Glad it is resolved.gomatze wrote:That did the Trick.
Matter solved
Locking
