check_nrpe operations on windows
Re: check_nrpe operations on windows
OK, I'm including an updated ini file so there is not confusion so you see what is currently running.
nsclient-EX206-2018-0815.ini- (28.89 KiB) Downloaded 307 times
My settings are the same, with the exception of this line:
and I am not having these issues.
How did you install NRPE on the Nagios Core machine? I wonder if it was compiled with no SSL support...
Run the following commands and show the output:
extended response = 0How did you install NRPE on the Nagios Core machine? I wonder if it was compiled with no SSL support...
/usr/local/nagios/bin/nrpe
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -nBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi lmiltchev.
I don't have the exact notes from my NRPE installation but I likely used something like these
- https://www.digitalocean.com/community/ ... untu-16-04
- Step 2 — Installing the check_nrpe Plugin
Here is the output I get from the commands:
/usr/local/nagios/libexec$ ./check_nrpe -H 127.0.0.1
CHECK_NRPE: Error receiving data from daemon.
/usr/local/nagios/libexec$ ./check_nrpe -H 127.0.0.1 -n
I imported your nsclient.ini into mine and changed the allowed hosts and it worked fine for mine. What are you seeing in your nsclient.log on that machine?
Try setting it to trace, restart the nsclient++ service, run a test and then see what the nsclient.log outputs:
Thank you
; LOG SECTION - Configure log properties.
[/settings/log]
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; LOG LEVEL - Log level to use. Available levels are error,warning,info,debug,trace
level = traceRe: check_nrpe operations on windows
Thanks for doing that, ssax. Your work (and lmiltchev) let me rule out my local nsclient.ini configuration.
The problem must be with my Nagios Core install or configuration.
Please see the attached log at trace level.
These are the commands I ran with the trace:
/usr/local/nagios/libexec$ ./check_nrpe -H 10.192.3.173
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
/usr/local/nagios/libexec$ ./check_nrpe -H 10.192.3.173 -c check_updates -t 30
The logs in question looked similar to what I've seen in the debug logs before:
2018-08-21 12:07:06: debug:c:\source\master\include\nrpe/server/protocol.hpp:92: Accepting connection from: 10.192.0.7, count=1
2018-08-21 12:07:06: error:c:\source\master\include\socket/connection.hpp:273: Seems we other end is not using ssl: unknown protocol
2018-08-21 12:07:06: error:c:\source\master\include\socket/connection.hpp:274: Please review the ssl option as well as ssl options in settings.
2018-08-21 12:07:28: debug:c:\source\master\include\check_nt/server/protocol.hpp:77: Accepting connection from: 10.192.0.7
nsclient-20180851-trace.log- (14.28 KiB) Downloaded 313 times
Seems we other end is not using sslCode: Select all
cd /tmp
rm -rf nrpe-3.2.1
curl -L -O https://github.com/NagiosEnterprises/nrpe/releases/download/nrpe-3.2.1/nrpe-3.2.1.tar.gz
tar zxf nrpe-3.2.1.tar.gz
cd nrpe-3.2.1
./configureRe: check_nrpe operations on windows
I've run the commands and attached the output.
As always, thank you.
57877-05 core nrpe configure.txt- (11.68 KiB) Downloaded 305 times
cd into the nrpe-3.2.1 directory and run this command:
Then cd into nrpe-3.2.1/src and run the check command from there and see if it works.
make allRe: check_nrpe operations on windows
When I do that, I get this response:
local:/tmp/nrpe-3.2.1$ make all
make: *** No rule to make target 'all'. Stop.
Running next command even though the first did not seem to work:
local:/tmp/nrpe-3.2.1/src$ ./check_nrpe -H 10.192.3.173
-bash: ./check_nrpe: No such file or directory
local:/tmp/nrpe-3.2.1/src$ dir
acl.c check_nrpe.c Makefile.in nrpe.c snprintf.c utils.c
I would try and reinstall the NRPE Agent and plugin using this KB article.
https://support.nagios.com/kb/article/n ... e-515.html
Something must of went wrong in your previous try so delete all of that and try it again.
On the bottom of the article has the "Install check_nrpe Plugin Only" section.
