Nagios Event handler not working
thanigaivel.a
Re: Nagios Event handler not working
Post by thanigaivel.a »
[root@indeta3appu001 eventhandlers]# su nagios -c /usr/local/nagios/libexec/eventhandlers/event_handler_service 13.61.25.230_gdcsdbpecs 13.61.25.230_gdcsdbpecs 13.61.25.230 Swap Usage Swap Usage OK HARD 0 9228 20806
[quote][quote]See the output[/quote][/quote]
thanigaivel.a
I didn't get any error
thanigaivel.a
Here is the output for HARD. (still no error)
I'm sorry I missed the quotes
su nagios -c '/usr/local/nagios/libexec/eventhandlers/event_handler_service 13.61.25.230_gdcsdbpecs 13.61.25.230_gdcsdbpecs 13.61.25.230 Swap Usage Swap Usage OK HARD 0 9228 20806'
thanigaivel.a
FYI
[root@indeta3appu001 eventhandlers]# su nagios -c '/usr/local/nagios/libexec/eventhandlers/event_handler_service 13.61.25.230_gdcsdbpecs 13.61.25.230_gdcsdbpecs 13.61.25.230 Swap Usage Swap Usage OK HARD 0 9228 20806'
This all appears to be correct.
You may want to modify the event handler to add the following to the end, so it would log any errors output when it runs from within nagios
$USER2$/event_handler_service $HOSTNAME$ $HOSTALIAS$ $HOSTADDRESS$ $SERVICEDISPLAYNAME$ $SERVICEDESC$ $SERVICESTATE$ $SERVICESTATETYPE$ $SERVICEPROBLEMID$ $LASTSERVICEPROBLEMID$ $SERVICEEVENTID$ $SERVICEOUTPUT$ $LONGSERVICEOUTPUT$ >> /tmp/event_handler_service.log 2>&1
then you can look in /tmp/event_handler_service.log if it gives an error in the log
