(host check orphaned, is the mod-gearman worker on queue 'ho
ssax
Dreams In Code
Re: (host check orphaned, is the mod-gearman worker on queue
Post by ssax »
We have checked the load on worker servers but its not an issue.
Did you check the load on the remote machines giving the errors during that time?
Is it only the host checks that are orphaned? Do any of the services give orphaned messages for those systems when they host reports that?
Have you tried stopping and restarting the nagios and mod_gearman services on the XI server and the workers to see if that resolves it?
What is the version of gearman installed on the XI server AND on the workers?
rpm -qa | grep gearman
progressive.nagiosXI
Post by progressive.nagiosXI »
there is a problem with Host check only service checks are working fine.
[root@monitoring-nagiosxi ~]# rpm -qa | grep gearman
gearmand-server-0.33-2.x86_64
gearmand-0.33-2.x86_64
mod_gearman2-2.1.1-1.el7.centos.x86_64
gearmand-devel-0.33-2.x86_64
gearmand-debuginfo-0.33-2.x86_64
This is the output we get when we run status of our gearmand
[root@monitoring-nagiosxi ~]# systemctl status gearmand
● gearmand.service - LSB: start and stop the Gearman server
Loaded: loaded (/etc/rc.d/init.d/gearmand; bad; vendor preset: disabled)
Active: failed (Result: timeout) since Wed 2018-10-31 00:02:57 IST; 10h ago
Docs: man:systemd-sysv-generator(8)
Process: 836 ExecStart=/etc/rc.d/init.d/gearmand start (code=exited, status=0/ SUCCESS)
CGroup: /system.slice/gearmand.service
└─2217 /usr/sbin/gearmand -d --worker-wakeup=10 --retention-file=/...
Oct 30 23:57:57 monitoring-nagiosxi.progressive.in systemd[1]: Starting LSB: ...
Oct 30 23:57:58 monitoring-nagiosxi.progressive.in runuser[838]: pam_unix(run...
Oct 30 23:57:59 monitoring-nagiosxi.progressive.in runuser[838]: pam_unix(run...
Oct 30 23:57:59 monitoring-nagiosxi.progressive.in gearmand[836]: Starting ge...
Oct 30 23:57:59 monitoring-nagiosxi.progressive.in gearmand[836]: /etc/rc.d/i...
Oct 30 23:57:59 monitoring-nagiosxi.progressive.in systemd[1]: PID file /var/...
Oct 31 00:02:57 monitoring-nagiosxi.progressive.in systemd[1]: gearmand.servi...
Oct 31 00:02:57 monitoring-nagiosxi.progressive.in systemd[1]: Failed to star...
Oct 31 00:02:57 monitoring-nagiosxi.progressive.in systemd[1]: Unit gearmand....
Hint: Some lines were ellipsized, use -l to show in full.
Without any debugging information or errors, it is hard to determine that the issue is so let's enable debugging.
On the system running the Gearman server edit the following file
/etc/mod_gearman2/module.conf
Change this from
debug=0
to
debug=1
Save the file and restart the gearman server.
On the workers, edit this file
Change this from
debug=0
to
debug=1
Save the file and restart the gearman worker.
The next time you have the host check orphaned message, look at the Gearman server log file at this location
/var/log/mod_gearman2/mod_gearman_neb.log
and the Gearman Worker log file at this location
/var/log/mod_gearman2/mod_gearman_worker.log
for any errors that happen at the time of the orphan message to see if you can figure out why the message is happening.
You may want to implement the check_gearman plugin on the Nagios server so it can check the status of the Gearman Server / Worker to see if it is still functioning.
See this link under the How To section
https://labs.consol.de/nagios/mod-gearman/index.html
Hi Team,
We are again facing the issue and we have find below please suggest
2018-11-12 16:00:05 - localhost:4730 - v0.33
Queue Name | Worker Available | Jobs Waiting | Jobs Running
check_results | 1 | 0 | 0
eventhandler | 296 | 0 | 0
host | 4 | 0 | 0
hostgroup_Ambicasteel | 31 | 0 | 28
hostgroup_Thomascook | 51 | 0 | 48
hostgroup_dnatamonitor | 49 | 0 | 49
hostgroup_hungama | 4 | 0 | 0
hostgroup_instarem | 50 | 102 | 50
hostgroup_laptop | 7 | 0 | 0
hostgroup_medanta | 50 | 9 | 50
hostgroup_somanyserver | 50 | 54 | 50
service | 4 | 0 | 0
worker_AS-MONITOR-SERVER | 1 | 0 | 0
worker_Hungama.NagiosXI | 1 | 0 | 0
worker_LTOB-Monitor | 1 | 0 | 0
worker_dcm.somany.com | 0 | 0 | 0
worker_ip-10-0-1-51.eu-west-1.compute.internal | 1 | 0 | 0
worker_localhost.localdomain | 2 | 0 | 0
worker_medanta.monitoring | 1 | 0 | 0
worker_monitoring-nagiosxi.progressive.in | 0 | 0 | 0
worker_nod-s-nagios.com | 1 | 0 | 0
and after some time its giving below error
2018-11-12 16:01:32 - localhost:4730 - v0.33
error reading from localhost:4730 - Interrupted system call
Which ever server gave that message, change the server option to use the IP address instead of the localhost entry.
server=127.0.0.1:4730
Its our monitoring server mod-gearman server.
Why my gearmand service showing failed in my gearman server (Nagios XI)
Active: failed (Result: timeout) since Mon 2018-11-05 10:12:02 IST; 1 weeks 2 days ago
Process: 978 ExecStart=/etc/rc.d/init.d/gearmand start (code=exited, status=0/SUCCESS)
└─1088 /usr/sbin/gearmand -d --worker-wakeup=10 --retention-file=/tmp/gearmand.retention -q retention --log-file=/var/log/gearmand/gearmand.log
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
also it happes some time all gearman checks stops without any intemation and maintaiin the last check data this is very critical
I have done the changes as per your recomendation from localhost to IP addrss but still getting the same probelm
Note --> all activity has been done in Nagios XI server (Mod-Gearman-server), after chnages in config file i have restarted mod-gearman-worker service.
2018-11-14 17:28:11 - localhost:4730 - v0.33
eventhandler | 343 | 0 | 0
host | 4 | 0 | 0
hostgroup_Ambicasteel | 32 | 0 | 28
hostgroup_HTMEDIA | 32 | 0 | 28
hostgroup_Thomascook | 60 | 0 | 55
hostgroup_dnatamonitor | 83 | 0 | 83
hostgroup_hungama | 3 | 0 | 0
hostgroup_instarem | 45 | 0 | 42
hostgroup_laptop | 6 | 0 | 0
hostgroup_medanta | 33 | 0 | 33
hostgroup_somanyserver | 45 | 0 | 41
service | 4 | 0 | 0
worker_dcm.somany.com | 1 | 0 | 0
worker_medanta.monitoring | 0 | 0 | 0
worker_nod-s-nagios.com | 0 | 0 | 0
Can you post the Mod Gearman Logfiles from all of the servers so we can check them?
Hi Teamm
These files are in gegabyte around 15 GB
