Hi so I just found out that the link I generate must be generated by the same user I use to connect. The Dashboard id will change for each user.
Was not expecting that.
Case solved
Sandro
Problems viewing Dashboards.
Re: Problems viewing Dashboards.
Yes, sorry I didn't mention that, the id's are unique to the user.nagiosEngie wrote:Hi so I just found out that the link I generate must be generated by the same user I use to connect. The Dashboard id will change for each user.
Case solved
Sandro
glad it is solved.
Locking thread.
