service nagios stop
service ndo2db stop
mv /usr/local/nagios/var/ndo2db.lock /usr/local/nagios/var/ndo2db.lock.bak
mv /usr/local/nagios/var/ndo.sock /usr/local/nagios/var/ndo.sock.bak
service ndo2db start
service nagios start
Blank service check
npolovenko
- Support Tech
Re: Blank service check
@hbouma, Can you run the following commands in order and let me know if it fixes the problem?
Unfortunately, it did not. When I tried to move the files, I was told that neither existed.
$ mv /usr/local/nagios/var/ndo2db.lock /usr/local/nagios/var/ndo2db.lock.bak
mv: cannot stat ‘/usr/local/nagios/var/ndo2db.lock’: No such file or directory
$ mv /usr/local/nagios/var/ndo.sock /usr/local/nagios/var/ndo.sock.bak
mv: cannot stat ‘/usr/local/nagios/var/ndo.sock’: No such file or directory
npolovenko
- Support Tech
@hbouma, Yeah that's normal(these files are supposed to get removed automatically. But sometimes they don't and that's why I included these commands). Did you run through the rest of the commands? Also in your profile, I can see that the DB is offloaded. Can you ssh to the remote DB server and check the log files? You can also run the following command on the remote server(you may need to replace the password for the root):
mysqlcheck -r -f -uroot -pnagiosxi --all-databases
All commands in your post were run.
MariaDB log is clean.
Database check run. The issue still exists.
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.host OK
mysql.ndb_binlog_index OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.servers OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.user OK
nagios.nagios_acknowledgements OK
nagios.nagios_commands OK
nagios.nagios_commenthistory OK
nagios.nagios_comments OK
nagios.nagios_configfiles OK
nagios.nagios_configfilevariables OK
nagios.nagios_conninfo OK
nagios.nagios_contact_addresses OK
nagios.nagios_contact_notificationcommands OK
nagios.nagios_contactgroup_members OK
nagios.nagios_contactgroups OK
nagios.nagios_contactnotificationmethods OK
nagios.nagios_contactnotifications OK
nagios.nagios_contacts OK
nagios.nagios_contactstatus OK
nagios.nagios_customvariables OK
nagios.nagios_customvariablestatus OK
nagios.nagios_dbversion OK
nagios.nagios_downtimehistory OK
nagios.nagios_eventhandlers OK
nagios.nagios_externalcommands OK
nagios.nagios_flappinghistory OK
nagios.nagios_host_contactgroups OK
nagios.nagios_host_contacts OK
nagios.nagios_host_parenthosts OK
nagios.nagios_hostchecks OK
nagios.nagios_hostdependencies OK
nagios.nagios_hostescalation_contactgroups OK
nagios.nagios_hostescalation_contacts OK
nagios.nagios_hostescalations OK
nagios.nagios_hostgroup_members OK
nagios.nagios_hostgroups OK
nagios.nagios_hosts OK
nagios.nagios_hoststatus OK
nagios.nagios_instances OK
nagios.nagios_logentries OK
nagios.nagios_notifications OK
nagios.nagios_objects OK
nagios.nagios_processevents OK
nagios.nagios_programstatus OK
nagios.nagios_runtimevariables OK
nagios.nagios_scheduleddowntime OK
nagios.nagios_service_contactgroups OK
nagios.nagios_service_contacts OK
nagios.nagios_service_parentservices OK
nagios.nagios_servicechecks OK
nagios.nagios_servicedependencies OK
nagios.nagios_serviceescalation_contactgroups OK
nagios.nagios_serviceescalation_contacts OK
nagios.nagios_serviceescalations OK
nagios.nagios_servicegroup_members OK
nagios.nagios_servicegroups OK
nagios.nagios_services OK
nagios.nagios_servicestatus OK
nagios.nagios_statehistory OK
nagios.nagios_systemcommands OK
nagios.nagios_timedeventqueue OK
nagios.nagios_timedevents OK
nagios.nagios_timeperiod_timeranges OK
nagios.nagios_timeperiods OK
nagiosql.tbl_command OK
nagiosql.tbl_contact OK
nagiosql.tbl_contactgroup OK
nagiosql.tbl_contacttemplate OK
nagiosql.tbl_domain OK
nagiosql.tbl_host OK
nagiosql.tbl_hostdependency OK
nagiosql.tbl_hostescalation OK
nagiosql.tbl_hostextinfo OK
nagiosql.tbl_hostgroup OK
nagiosql.tbl_hosttemplate OK
nagiosql.tbl_info OK
nagiosql.tbl_lnkContactToCommandHost OK
nagiosql.tbl_lnkContactToCommandService OK
nagiosql.tbl_lnkContactToContactgroup OK
nagiosql.tbl_lnkContactToContacttemplate OK
nagiosql.tbl_lnkContactToVariabledefinition OK
nagiosql.tbl_lnkContactgroupToContact OK
nagiosql.tbl_lnkContactgroupToContactgroup OK
nagiosql.tbl_lnkContacttemplateToCommandHost OK
nagiosql.tbl_lnkContacttemplateToCommandService OK
nagiosql.tbl_lnkContacttemplateToContactgroup OK
nagiosql.tbl_lnkContacttemplateToContacttemplate OK
nagiosql.tbl_lnkContacttemplateToVariabledefinition OK
nagiosql.tbl_lnkHostToContact OK
nagiosql.tbl_lnkHostToContactgroup OK
nagiosql.tbl_lnkHostToHost OK
nagiosql.tbl_lnkHostToHostgroup OK
nagiosql.tbl_lnkHostToHosttemplate OK
nagiosql.tbl_lnkHostToVariabledefinition OK
nagiosql.tbl_lnkHostdependencyToHost_DH OK
nagiosql.tbl_lnkHostdependencyToHost_H OK
nagiosql.tbl_lnkHostdependencyToHostgroup_DH OK
nagiosql.tbl_lnkHostdependencyToHostgroup_H OK
nagiosql.tbl_lnkHostescalationToContact OK
nagiosql.tbl_lnkHostescalationToContactgroup OK
nagiosql.tbl_lnkHostescalationToHost OK
nagiosql.tbl_lnkHostescalationToHostgroup OK
nagiosql.tbl_lnkHostgroupToHost OK
nagiosql.tbl_lnkHostgroupToHostgroup OK
nagiosql.tbl_lnkHosttemplateToContact OK
nagiosql.tbl_lnkHosttemplateToContactgroup OK
nagiosql.tbl_lnkHosttemplateToHost OK
nagiosql.tbl_lnkHosttemplateToHostgroup OK
nagiosql.tbl_lnkHosttemplateToHosttemplate OK
nagiosql.tbl_lnkHosttemplateToVariabledefinition OK
nagiosql.tbl_lnkServiceToContact OK
nagiosql.tbl_lnkServiceToContactgroup OK
nagiosql.tbl_lnkServiceToHost OK
nagiosql.tbl_lnkServiceToHostgroup OK
nagiosql.tbl_lnkServiceToServicegroup OK
nagiosql.tbl_lnkServiceToServicetemplate OK
nagiosql.tbl_lnkServiceToVariabledefinition OK
nagiosql.tbl_lnkServicedependencyToHost_DH OK
nagiosql.tbl_lnkServicedependencyToHost_H OK
nagiosql.tbl_lnkServicedependencyToHostgroup_DH OK
nagiosql.tbl_lnkServicedependencyToHostgroup_H OK
nagiosql.tbl_lnkServicedependencyToService_DS OK
nagiosql.tbl_lnkServicedependencyToService_S OK
nagiosql.tbl_lnkServiceescalationToContact OK
nagiosql.tbl_lnkServiceescalationToContactgroup OK
nagiosql.tbl_lnkServiceescalationToHost OK
nagiosql.tbl_lnkServiceescalationToHostgroup OK
nagiosql.tbl_lnkServiceescalationToService OK
nagiosql.tbl_lnkServicegroupToService OK
nagiosql.tbl_lnkServicegroupToServicegroup OK
nagiosql.tbl_lnkServicetemplateToContact OK
nagiosql.tbl_lnkServicetemplateToContactgroup OK
nagiosql.tbl_lnkServicetemplateToHost OK
nagiosql.tbl_lnkServicetemplateToHostgroup OK
nagiosql.tbl_lnkServicetemplateToServicegroup OK
nagiosql.tbl_lnkServicetemplateToServicetemplate OK
nagiosql.tbl_lnkServicetemplateToVariabledefinition OK
nagiosql.tbl_lnkTimeperiodToTimeperiod OK
nagiosql.tbl_logbook OK
nagiosql.tbl_mainmenu OK
nagiosql.tbl_permission
note : The storage engine for the table doesn't support repair
nagiosql.tbl_permission_inactive
nagiosql.tbl_service OK
nagiosql.tbl_servicedependency OK
nagiosql.tbl_serviceescalation OK
nagiosql.tbl_serviceextinfo OK
nagiosql.tbl_servicegroup OK
nagiosql.tbl_servicetemplate OK
nagiosql.tbl_session OK
nagiosql.tbl_session_locks OK
nagiosql.tbl_settings OK
nagiosql.tbl_submenu OK
nagiosql.tbl_timedefinition OK
nagiosql.tbl_timeperiod OK
nagiosql.tbl_user OK
nagiosql.tbl_variabledefinition OK
nagiosxi.xi_auditlog OK
nagiosxi.xi_auth_tokens
nagiosxi.xi_cmp_trapdata
nagiosxi.xi_cmp_trapdata_log
nagiosxi.xi_commands OK
nagiosxi.xi_eventqueue OK
nagiosxi.xi_events OK
nagiosxi.xi_incidents
nagiosxi.xi_meta OK
nagiosxi.xi_options OK
nagiosxi.xi_sessions
nagiosxi.xi_sysstat OK
nagiosxi.xi_usermeta OK
nagiosxi.xi_users OK
npolovenko
- Support Tech
@hbouma, Can you sign in to the Core interface and check if you see the blank service check there?
*When it prompts for the login and password you can enter the nagiosadmin login and password
*Replace 192.168.3.87 with your XI IP address
The issue does not show up in our Nagios Core interface.
npolovenko
- Support Tech
@hbouma, What is the output of?
Nagios is not showing up in the list of processes in your profile. I'm not sure if it's running now. If not, try to start it:
service nagios statusservice nagios start
$ systemctl status nagios
● nagios.service - LSB: Starts and stops the Nagios monitoring server
Loaded: loaded (/etc/rc.d/init.d/nagios; bad; vendor preset: disabled)
Active: active (exited) since Thu 2018-09-06 10:50:11 EDT; 3h 3min ago
Docs: man:systemd-sysv-generator(8)
Process: 1547 ExecStop=/etc/rc.d/init.d/nagios stop (code=exited, status=0/SUCCESS)
Process: 5131 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=0/SUCCESS)
npolovenko
- Support Tech
@hbouma, This looks like the issue discussed here:
https://github.com/NagiosEnterprises/na ... issues/164
What version of XI are you running and what is the operating system? Have you updated this XI installation recently?
We are running Nagios XI 5.5.3 on Red Hat 7 64bit. We recently upgraded from 5.5.1 to 5.5.3 on all 6 of our Nagios XI servers and are not seeing the issue on anything but the one server.
I would disagree that the issue is different. The process is running. I can see it in the output of a ps command. When running a systemctl reload nagios, it completes properly and the service shows active when I run a systemctl status nagios, which is different than what is in that bug. I can also see full access to the resource.cfg file.
-rw-rw-r--. 1 apache nagios 210 Apr 9 16:33 resource.cfgCode: Select all
$ systemctl reload nagios
07:40 AM [i]SERVER[/i] root
Active: active (running) since Thu 2018-09-06 16:35:05 EDT; 15h ago
Process: 19225 ExecStop=/etc/rc.d/init.d/nagios stop (code=exited, status=0/SUCCESS)
Process: 27150 ExecReload=/etc/rc.d/init.d/nagios reload (code=exited, status=0/SUCCESS)
Process: 19244 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=0/SUCCESS)
