drwsrwsr-x. 2 apache nagios 4096 Oct 10 16:28 /usr/local/nagiosfusion/tmp
Fusion version 4.1.5 dashboard
Re: Fusion version 4.1.5 dashboard
These permissions look correct, lets looks at the following commands:
ls -dl /usr/local/nagiosfusion/
getenforceRe: Fusion version 4.1.5 dashboard
getenforcedrwxr-xr-x. 7 nagios nagios 4096 Aug 7 17:52 /usr/local/nagiosfusion/
Disabled
I'm not sure why you are getting that error, but for the immediate fix, you can open the zip and grab the noc/dashlets/open_host_problems.php file and replace the file on your server found at
That file contains the fix.
/usr/local/nagiosfusion/html/includes/components/noc/dashlets/open_host_problems.phpRe: Fusion version 4.1.5 dashboard
Thanks scottwilkerson!
The new component is working greate!
I have another problem with the dashboard "Open Problems Summary".
This dashboard show me the all hosts and services which are down in all my customers and not just what I can see in the Fusion )like in Fusion 2014).
I need that this dashboard will show only the hosts and services which appear in the Fusion at the same time.
Can you please provide the same component like before with my request?
Do you mean the "Show Unhandled" is also showing those in downtime in this dashlet as well?elade wrote:Thanks scottwilkerson!
Yes in dashboard Open Problems Summary
Also there is any way to select a few servers in one dashboard and not just 1 server or all?
Attached is a file that should get this really close to matching, it can get unzipped and placed in
/usr/local/nagiosfusion/html/includes/components/noc/dashlets/for the Open Problem dashlets, there isn't any way to select a sub-set of hosts/services other than by Nagios XI server.elade wrote:Also there is any way to select a few servers in one dashboard and not just 1 server or all?
Hi scottwilkerson
Thank you for your help!.
You can close the post.
great! Locking threadelade wrote:Hi scottwilkerson
