NagiosXI Install Issue
pshankland
Re: NagiosXI Install Issue
Post by pshankland »
Right, did a fresh install of CentOS 6.2 32Bit minimal. All I then did was:
  • Configured networking
    Modified yum.conf for proxy
    Installed vim and wget
    Modified wgetrc for proxy
    Disabled SELINUX
    Added a new user for SSH access
    Disabled root from SSH access
    yum update -y
    Reboot
After all this I ran the following commands to install NagiosXI:
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./fullinstall
Again, I have got the following error:
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system
that has been tasked with other purposes or has an existing install of Nagios Core. To create such a clean install
you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-yum'...
Configuring Yum...
centos-release-6-2.el6.centos.7.i686
Enabling RPMForge repo...
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-yum'
I have attached the install.log file again but it is identical to the first one.
Anything??
Can I have you run the following from the command line and report the results
curl -s http://repoforge.org/use/ | grep -o "http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-[0-9.-]\+.el6.rf.i686.rpm"
