SQL Database Size check not working
kwhogster
Re: SQL Database Size check not working
Post by kwhogster »
I figured it out.
Had to create an AD Security group and added the SQL servers as members
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/check_nrpe -t 50 -H 'TGCS014-N1' -c check_sqldbsize -a 'TGCS014-N1-SQLW\wrestling wrestlinghistory 8000 5000'
OK: WRESTLINGHISTORY database size is 3 MB.
Now working
The can now be locked as resolved.
Thanks for all your help
kwhogster
Post by kwhogster »
Ooops Spoke to soon.
The update is It works on my SQL 2012 Server no problem, It also works on my SQL 2014 Server but that server has three instances.
I thought once I got it working on one instance the others would work I was wrong.
I get the a different error now but it is the same for both instances.
/usr/local/nagios/etc/objects/windowsservers# /usr/lib/nagios/plugins/check_nrpe -t 50 -H 'TGCS014-N1' -c check_sqldbsize -a 'TGCS014-N1-SQLC\ORF 8000 5000'
C:\Program Files\NSClient++\scripts\check_sqldbsize.vbs(25, 15) Microsoft VBScript runtime error: Type mismatch: 'cint'
/usr/local/nagios/etc/objects/windowsservers# /usr/lib/nagios/plugins/check_nrpe -t 50 -H 'TGCS014-N1' -c check_sqldbsize -a 'TGCS014-N1-SQLS\WSS_Content 8000 5000'
from the server I ran the command against both instances and it works fine. Just from the Nagios server I get the above error
C:\Program Files\NSClient++\scripts>cscript check_sqldbsize.vbs TGCS014-N1-SQLC ORF 6000 9000
Microsoft (R) Windows Script Host Version 5.8
Copyright (C) Microsoft Corporation. All rights reserved.
OK: ORF database size is 3 MB.
C:\Program Files\NSClient++\scripts>cscript check_sqldbsize.vbs TGCS014-N1-SQLS WSS_Content 6000 9000
OK: WSS_CONTENT database size is 45 MB.
Any ideas on the CINT error?
I would guess that the the plugin is getting invalid data from the server and is having problems converting that data to an integer and is generating an error.
Check the SQL logs for any permission errors.
Verify the command is correct in the nsclient.ini file.
Check the nsclient.log file for any errors. It is in this folder.
If you cannot figure it out, contact the Author of the plugin for any help or troubleshooting tips.
kwhogster
Post by kwhogster »
That's what I thought but why does the one sql instance check work?
The nsclient.ini has one line and it is the same for all three instances
I checked the sql logs no errors reported during the check.
The nsclient log has no messages for the current date.
I tried to contact the author but the Nagios site never sends me an email to verify my account something is wrong on there,
Another thing to look at, if the 2 databases that are failing are very large, that could cause the error.
The plugin uses an integer for the warning and critical values and is the data returned it larger than an integer, it could generate that error.
kwhogster
Post by kwhogster »
not the case here
When I run the script locally
Databases are very small
I missed it from earlier but your command examples that are generating the error are missing one of the arguments.
kwhogster
Post by kwhogster »
Good call
I had a / between the server name and the database name
removed that and it worked.
This is now resolved.
Glad it is working now. Let us know if it is OK to lock the post as solved.
