Nagios XI no longer uploads a plugin after 5.5.7 update
alsoszaa
Re: Nagios XI no longer uploads a plugin after 5.5.7 update
Post by alsoszaa »
Running this: cat /etc/php.ini | grep upload_max_filesize
Outputs: upload_max_filesize = 20M
Running this: ls -ld /tmp
Outputs: drwxrwxrwt. 17 root root 4096 Nov 19 11:36 /tmp
changed values in PHP.ini:
error_reporting = E_ALL
display_errors = On
memory_limit was at 256 (default). but changed to 512
After retrying to upload a plugin I still see the same issue.
The log is filled with this message:
[Mon Nov 19 13:58:49.357691 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.357723 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358670 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358716 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358748 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358777 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358797 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358815 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358874 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358905 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358930 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:49.358969 2018] [:error] [pid 117271] [client 146.129.228.81:61211] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:53.103226 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.103302 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105025 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105074 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105114 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105155 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105199 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.105249 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106300 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106346 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106377 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106406 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106426 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106444 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106472 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106515 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106541 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.106579 2018] [:error] [pid 117707] [client 146.129.228.81:61218] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.107663 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.107715 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/
[Mon Nov 19 13:58:53.613187 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.613263 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.615332 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.615369 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.615410 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.616887 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.616940 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.616997 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.618231 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.618268 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.618302 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.619568 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.619629 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.619674 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.619719 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.621570 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.621612 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.621638 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.621671 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623073 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623120 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623159 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623191 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623221 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623247 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.623279 2018] [:error] [pid 117359] [client 146.129.228.81:61219] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.654951 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.655026 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.656400 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.656437 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.656469 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.657610 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.657645 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.657692 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.658857 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.658898 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.658925 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.658970 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.660155 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.660196 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.660222 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.660251 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661378 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661410 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661441 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661482 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661508 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:53.661554 2018] [:error] [pid 118806] [client 146.129.228.81:61217] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/includes/page-default-splash.php
[Mon Nov 19 13:58:59.921757 2018] [:error] [pid 118465] [client 146.129.228.81:61223] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.921848 2018] [:error] [pid 118465] [client 146.129.228.81:61223] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.996270 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.996335 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998074 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998107 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998146 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998178 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998203 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.998233 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999181 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999243 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999281 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999311 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999331 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999349 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999376 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999404 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999428 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
[Mon Nov 19 13:58:59.999466 2018] [:error] [pid 117337] [client 146.129.228.81:61222] PHP Deprecated:  mysql_escape_string(): This function is deprecated; use mysql_real_escape_string() instead. in /usr/local/nagiosxi/html/includes/db.inc.php on line 368, referer: http://dja-tst-nagios/nagiosxi/admin/
npolovenko
Post by npolovenko »
@alsoszaa, Please run this command from the command line:
tail -f ssl_error_log
And while its running try uploading a plugin one more time. Let me know if you'll see any errors in the command line output.
