Webinject matching content
lpereira
Re: Webinject matching content
Post by lpereira »
scottwilkerson wrote:Your PM stated the new error was
lpereira wrote:
"WebInject CRITICAL - Test case number 1 failed"
This is different than the error you posted in the thread
(Return code of 25 for service 'CRONOS' on host 'CRONOS' was out of bounds)
No close element tag [Ln: 14, Col: 57]
Are you 100% sure there are no other fields required to be posted? this could cause it to not authenticate properly.
i figured out that one line has double quotation lines at the end. That's why the out of bound message. After i corrected that. i got the error i mentioned before
Are you 100% sure there are no other fields required to be posted with the authentication? This could cause it to not authenticate properly, and likely not return the output you expect.
I also did notice the lack of a / in our examples we were using too
<testvar varname="LOGIN_URL">http:/XXX.XXX.XXX/csl/check</testvar>
should be
<testvar varname="LOGIN_URL">http://XXX.XXX.XXX/csl/check</testvar>
Can you run the following and post the output?
curl -X POST -vvv -d 'login=LOGIN&passwd=PASSWORD' http://XXX.XXX.XXX/csl/check
lpereira
Post by lpereira »
scottwilkerson wrote:Are you 100% sure there are no other fields required to be posted with the authentication? This could cause it to not authenticate properly, and likely not return the output you expect.
should be
here is the output of the command you requested.
[root@nagios webinject]# curl -X POST -vvv -d 'login=LOGIN&passwd=PASSWORD' http://XXX.XXX.XXX/csl/check
* About to connect() to XXX.XXX.XXX port 80 (#0)
*   Trying XXX.XXX.XXX... connected
* Connected to XXX.XXX.XXX (XXX.XXX.XXX) port 80 (#0)
> POST /csl/check HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.27.1 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: XXX.XXX.XXX
> Accept: */*
> Content-Length: 25
> Content-Type: application/x-www-form-urlencoded
* HTTP 1.0, assume close after body
< HTTP/1.0 200 OK
< Server: ZK Web Server
< Pragma: no-cache
< Cache-control: no-cache
< Content-Type: text/html;
< Connection: close
        <HTML>
        <HEAD><TITLE></TITLE>
        <META http-equiv=Content-Type content='text/html;'>
        </HEAD>
        <BODY topMargin=0 leftMargin=0>
<Script language=JavaScript type='text/javascript'>alert('Failed'+':'+'Error Input!');self.location.href='/';</Script>
        </BODY></HTML>
* Closing connection #0
Regarding the question. I Think there are no other field required for the authentication. i also checked the missing "/" the script is correct, i accidentally removed one / when i replaced with the X. the xml is fine
So the content of the page that was returned is this, which does not contain your match string
<HTML>
        </HEAD>
        </BODY></HTML>
lpereira
Post by lpereira »
scottwilkerson wrote:So the content of the page that was returned is this, which does not contain your match string
<HTML>
        </HEAD>
        </BODY></HTML>
ok i founded what the error was... the user and password field wasn't the same on your example than the one i have on my web.
[root@nagios webinject]# curl -X POST -vvv -d 'username=USER&userpwd=PASS' http://IP/csl/check
* About to connect() to IP port 80 (#0)
* Trying IP... connected
* Connected to IP (IP) port 80 (#0)
> Host: IP
> Accept: */*
> Content-Length: 28
< HTTP/1.0 200 OK
< Pragma: no-cache
< Connection: close
HTTP/1.0 200 OK
Pragma: no-cache
Connection: close
<html><head><title></title><script language=JavaScript type='text/javascript'>top.location.href='/'</script></head><body></body></html>
i asked a partner and he told me that the string i need to find is under an iFrame. i modified the script (via CLI editing the testcases.xml).
now the check has 2 parts, the first one log in on the web page and the second one, look for the match to string.
Let me show you the code
<testcases repeat="1">
    id="1"
    description1="short description"
    description2="long description"
    method="post"
    url="http://IP/csl/check"
    postbody="username=USER&userpwd=PASS"
</testcases>
  id="2"
    method="post"
    url="http://IP/csl/desktop"
    verifypositive="<TR><TD class=nrow>Transaction capacity</td><TD>30000/0</td><TD></td></tr>"
    logrequest="yes"
    logresponse="yes"
    sleep="3"
</testcases>
Now, when i run the check i got the following error
Only Comments, PIs and whitespace allowed at end of document [Ln: 10, Col: 1]
ssax
Dreams In Code
Post by ssax »
What is the output of this command?
curl -L -X POST -vvv -d 'username=USER&userpwd=PASS' http://IP/csl/check
Try this and see if it works for you:
    <case
    id="1"
    method="post"
    <case
    id="2"
    method="post"
    verifypositive="\<TR>\<TD class=nrow>Transaction capacity\</td>\<TD>30000/0\</td>\<TD>\</td>\</tr>"
    logrequest="yes"
    logresponse="yes"
    sleep="3"
</testcases>
lpereira
Post by lpereira »
ssax wrote:What is the output of this command?
    <case
    id="1"
    method="post"
    <case
    id="2"
    method="post"
    logrequest="yes"
    logresponse="yes"
    sleep="3"
</testcases>
no luck
> Content-Length: 28
< HTTP/1.0 200 OK
< Pragma: no-cache
< Connection: close
HTTP/1.0 200 OK
Pragma: no-cache
Connection: close
[root@nagios webinject]# /usr/local/nagios/libexec/check_webinject.sh CRONOS__CRONOS_config.xml
could not find ParserDetails.ini in /usr/lib64/perl5/XML/SAX
Use of uninitialized value $case{"postbody"} in string at ./webinject.pl line 611.
WebInject CRITICAL - Test case number 2 failed |time=10.132;30;;0
ssax
Dreams In Code
Post by ssax »
/usr/local/nagiosxi/etc/components/webinject/webinject.pl -c CRONOS__CRONOS_config.xml
lpereira
Post by lpereira »
i have made some modifications on the xml, still not working. The ouput of the command is
[root@nagios libexec]# /usr/local/nagiosxi/etc/components/webinject/webinject.pl -c CRONOS__CRONOS_config.xml
< character not allowed in attribute values [Ln: 16, Col: 86]
ssax
Dreams In Code
Post by ssax »
That error is related to the < in the verifypositive entry that I escaped in the one I sent you, please send me these files:
/usr/local/nagiosxi/etc/components/webinject/CRONOS__CRONOS_config.xml
/usr/local/nagiosxi/etc/components/webinject/CRONOS__CRONOS_testdata.xml
