Possible bug in check_http
bomahony
Re: Possible bug in check_http
Post by bomahony »
Nice one I tested both, and will probably go with the one that modifies the check_command. It seems the cleanest, as all our other checks use -H it will keep consistency.
You can close this off.
B
bomahony wrote:Nice one I tested both, and will probably go with the one that modifies the check_command. It seems the cleanest, as all our other checks use -H it will keep consistency.
B
Great.
Locking thread
