Monitoring Exchange Performance Data
REFan
Re: Monitoring Exchange Performance Data
Post by REFan »
Ive submitted a ticket with support to have this worked on but would still love any advice. It would be nice if we can adjust these services to keep their data history.
benjaminsmith
Post by benjaminsmith »
Hi @REFan,
I looked into tour npcd log file, this is the daemon that process your performance data and it's hitting max load.
[11-29-2018 11:17:22] NPCD: WARN: MAX load reached: load 11.370000/10.000000 at i=0
[11-29-2018 13:32:05] NPCD: WARN: MAX load reached: load 13.650000/10.000000 at i=0
[11-29-2018 13:32:20] NPCD: WARN: MAX load reached: load 10.900000/10.000000 at i=1
[11-30-2018 20:57:16] NPCD: WARN: MAX load reached: load 10.080000/10.000000 at i=0
First, check the the number for spooled files by running the following commands:
ls /usr/local/nagios/var/spool/perfdata/ | wc -l
ls /usr/local/nagios/var/spool/xidpe/ | wc -l
If this is very large, you can delete them by running:
find /usr/local/nagios/var/spool/perfdata/ -type f -delete
You can increase the max load threshold to 15 by editing /usr/local/nagios/etc/pnp/npcd.cfg, and change the following line:
load_threshold = 15.0
Then restart NPCD:
service npcd restart
Let me know this resolves the issue. You can tail the npcd log file for errors if it's not working:
tail -f /usr/local/nagios/var/npcd.log
Nagios XI - Performance Graph Problems
https://support.nagios.com/kb/article.php?id=9
REFan
Post by REFan »
The load was low when I just checked it. More likely the issue is the service itself is not saving history. I just heard back on the support ticket and they gave me this change that worked.
Changed my $ARG3$ value to this and now the history is saved and performance charts are available.
-l "\\MSExchangeTransport Queues(_total)\\Submission Queue Length","submission_queue_length","items"
Thank you for all your advice. Going to implement this with other services now.
benjaminsmith
Hi @REFan
Glad the issue has been worked out. I will go ahead and close this ticket. Thank you for using the Nagios Support Forum.
