My mistake, I gave you the patch for a more recent version of XI. The file attached to this post was tested against 5.5.6
If you do the same thing with this file, it should work this time.
Duplicate Service Definitions
swolf
Re: Duplicate Service Definitions
Hi swolf,swolf wrote:My mistake, I gave you the patch for a more recent version of XI. The file attached to this post was tested against 5.5.6
Its working fine. Thanks a ton for immediate resolution. Which NagiosXi Version I will get the fix in?
The fix will be in Nagios XI 5.5.8. Thank you!
