set up email alerts using mailx
Re: set up email alerts using mailx
Ive attached command.cfg file.
Here's the output.
[root@nagioscore ~]# ls -l /usr/bin/printf
-rwxr-xr-x. 1 root root 49776 Apr 11 2018 /usr/bin/printf
[root@nagioscore ~]# ls -l /usr/bin/mailx
-rwxr-xr-x. 1 root root 392880 Apr 11 2018 /usr/bin/mailx
Here's the output.
commands.cfg- (7.23 KiB) Downloaded 965 times
First, lest put back the New Lines back in to the commands so replace both of the command definitions with the following.
FYI, I tested out those commands and they both worked and did not generate any errors so the missing " must be somewhere else.
What I did find is that is looks like you tried to comment out thecheck_nt command but a few of the lines were missed so change the following section from
to
Save the change and restart nagios by running
Try testing the email commands by sending a custom notification and see if they work and do not generate the previous errors in the nagios.log file.
command_line /usr/bin/printf "%b" "***** Nagios Monitor Core Alert*****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nHost: $HOSTNAME$\n\nState: $HOSTSTATE$\n\nAddress: $HOSTADDRESS$\n\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
}Code: Select all
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios Monitor Core Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\n\nHost: $HOSTALIAS$\n\nAddress: $HOSTADDRESS$\n\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
}FYI, I tested out those commands and they both worked and did not generate any errors so the missing " must be somewhere else.
#define command {
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
#}Code: Select all
#define command {
# command_name check_nt
# command_line $USER1$/check_nt -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
#}Code: Select all
systemctl restart nagiosBe sure to check out our Knowledgebase for helpful articles and solutions!
I noticed there are two "n" on the "Address" and "Additional" field below. Is that a typo?
command_line /usr/bin/printf "%b" "***** Nagios Monitor Core Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\n\nHost: $HOSTALIAS$\n\nnAddress: $HOSTADDRESS$\n\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nnAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
Yes, that is a typo. I fixed the example.
Ive generated a test email by sending a custom notification as shown below:
[nagios@nagioscore objects]$ mailx -v -s "Test2" -S smtp=mailrelay.int.company.com -S from=[email protected] [email protected]
EOT
Null message body; hope that's ok
Resolving host mailrelay.int.company.com . . . done.
Connecting to 10.130.128.30:smtp . . . connected.
220 fihe3nok0735.emea.nsn-net.net ESMTP Thu, 10 Jan 2019 21:44:48 GMT
>>> HELO nagioscore
250 fihe3nok0735.emea.nsn-net.net Hello [10.3.17.130], pleased to meet you
>>> MAIL FROM:<[email protected]>
250 2.1.0 <[email protected]>... Sender ok
>>> RCPT TO:<[email protected]>
250 2.1.5 <[email protected]>... Recipient ok
>>> DATA
354 Enter mail, end with "." on a line by itself
250 2.0.0 x0ALimaO029780 Message accepted for delivery
>>> QUIT
221 2.0.0 fihe3nok0735.emea.nsn-net.net closing connection
Please see attached nagios log and mail log.
EOT
>>> HELO nagioscore
>>> DATA
>>> QUIT
nagios.log- (737.29 KiB) Downloaded 940 times
In your example, you are specifying a smtp server and a from address, did you add them to the Nagios commands?
Could you please help me here? Where should I put the information for smtp server and from address in the command.cfg file? Please see attached command.cfg config file. Thanks!
commands.cfg- (7.02 KiB) Downloaded 905 times
For the notify-service-by-email command, you would define the command line this. Adjust the values to the actual SMTP server and from address if needed.
For the notify-host-by-email command, do this
/usr/bin/printf "%b" "***** Nagios Monitor Core Alert*****\n\Notification Type: $NOTIFICATIONTYPE$\n\nHost: $HOSTNAME$\n\nState: $HOSTSTATE$\n\nAddress: $HOSTADDRESS$\n\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -S smtp=mailrelay.int.company.com -S [email protected] $CONTACTEMAIL$Code: Select all
/usr/bin/printf "%b" "***** Nagios Monitor Core Alert *****\n\Notification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\n\nHost: $HOSTALIAS$\n\nAddress: $HOSTADDRESS$\n\State: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nnAdditional Info:\n\n$SERVICEOUTPUT$\" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" -S smtp=mailrelay.int.company.com -S [email protected] $CONTACTEMAIL$Be sure to check out our Knowledgebase for helpful articles and solutions!
Ive made all the changes on the command.cfg file as instructed, and finally email notification it works but only on certain object file or hostgroup.
Ive created another object file called "linuxhosts.cfg" within object directory and added some hosts in this file. Ive configured nagios.cfg script and added linuxhosts.cfg dir path within the nagios.cfg script.
I ran some test by shutting down a host (rancid) completely, but nothing happen when I turn off the host, email notification didn't work.
Please see attached linuxhosts.cfg and command.cfg files.
linuxhosts.cfg- (10.36 KiB) Downloaded 1009 times
commands.cfg- (7.15 KiB) Downloaded 945 times
Your host called rancid has a Contact Group assigned to it called admin.
Make sure you have added a Contact that you want to receive emails to the Contact Group called admin and that will tie the contact to that host for receiving emails.
Also, make sure the contact is setup to receive emails. Just copy the settings from the working contact.
