error general time-out (alarm signal)
shamrozkadiwal
Re: error general time-out (alarm signal)
I changed the t value to 60 in the command.cfg file and also change the value of service_chceck_timeout=60 but having same error
Are you getting the "Invalid timeout value" error or the "Invalid timeout value" error?
shamrozkadiwal
getting "error general time-out (alarm signal)"
shamrozkadiwal
I am not sure where do I need to specify the SNMP version for the check_snmp plugin's command line and what version should I put it.
This is the 10.180.50.100 server
[root@ams900 ~]# nmap 10.180.50.100 -p 161 -sU
Starting Nmap 7.01 ( https://nmap.org ) at 2019-01-09 09:01 CST
Nmap scan report for asftp900.enclave.local (10.180.50.100)
Host is up (0.00035s latency).
PORT STATE SERVICE
161/udp open snmp
Nmap done: 1 IP address (1 host up) scanned in 0.15 seconds
[root@ams900 ~]#Code: Select all
[root@aus50ltasftp900 ~]# snmpd -v
NET-SNMP version: 5.7.2
Web: http://www.net-snmp.org/
Email: [email protected]
[root@aus50ltasftp900 ~]#Re: error general time-out (alarm signal)
The default snmpd.conf config file needs to be edited to allow certain OID's to be polled so it has to be changed to allow that.
I attached a copy of the file with pretty much all of the settings you may need so on the remote server, replace the /etc/snmp/snmpd.conf file with the attached copy.
Restart the snmpd daemon and test the command again.
snmpd.conf- (18.54 KiB) Downloaded 813 times
shamrozkadiwal
I replaced the snmpd.conf file with your file and still seeing the same error
Sorry, I forgot to mention this, the file I posted you have to use public as the community string and it is also setup to only use SNMP version 2 so you will have to add a -2 to the command and change the community string.
Try this example
Try this example
./check_snmp_storage.pl -H 10.180.50.100 -C public -t 60 -m / -r -q FixedDisk -w90 -c95 -G -2Be sure to check out our Knowledgebase for helpful articles and solutions!
shamrozkadiwal
@tgriep, I tried the command that you gave me and it works like charm
I was wondering can't I keep nag9899 instead of public.
[root@ams900 plugins]# ./check_snmp_storage.pl -H 10.180.50.100 -C public -t 60 -m / -r -q FixedDisk -w90 -c95 -G -2
/: 10%used(2GB/18GB) (<90%) : OKCode: Select all
[root@ams900 plugins]# ./check_snmp_storage.pl -H 10.180.50.100 -C nag9899 -t 60 -m / -r -q FixedDisk -w90 -c95 -G -2
ERROR: General time-out (Alarm signal)Re: error general time-out (alarm signal)
Edit the snmpd.conf file and change these lines from
to
Save the file and restart the snmpd daemon so the changes take affect.
com2sec notConfigUser default public
rocommunity publicCode: Select all
com2sec notConfigUser default nag9899
rocommunity nag9899Be sure to check out our Knowledgebase for helpful articles and solutions!
shamrozkadiwal
Awesome! Everything looks good now. Thanks for help
