Hostgroup Summary - requires authentication
Re: Hostgroup Summary - requires authentication
SteveBeauchemin wrote:The file works for me. Am I able to get that file from a Nagios XI 5.4.13 install if I need it again? In case I have to do a new install and add mod_gearman. Or is this a custom fix just for me. Just curious.
the file I gave you should work just fine on 5.5.0+, I cannot create the file if you were to downgrade a complete system to 5.4.13, however it wouldn't be needed because the file included with 5.4.13 would be correct.
SteveBeauchemin wrote: Also, I noticed that the file - /usr/local/nagiosxi/etc/htpasswd.users - is still not getting a new time stamp when I login. I even updated an account password in AD, logged in using the LDAP / DUO authentications. Got in okay. The file did not update.
Is that file needed any more? Or is that now unused. Do I need to be concerned.
this actually doesn't matter and the file actually shouldn't update unless you are adding a new user, or logging in for the first time.
SteveBeauchemin
Post by SteveBeauchemin »
Okay then. Problem solved.
Please close.
Thank You !
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
SteveBeauchemin wrote:Okay then. Problem solved.
Please close.
Thank You !
Steve B
Great! Locking thread
