It uses the older syntax and that is why I use the -2 parameter on check_nrpe.
We remove many items we do not need to know about. Tests run every 5 minutes.
Check Command definition
/usr/local/nagios/libexec/check_nrpe -2 -u -t 60:3 --host $HOSTADDRESS$ --command $ARG1$ $ARG2$ $ARG3$ $ARG4$ $ARG5$ $ARG6$ $ARG7$ $ARG8$Config Name = svc-NRPE-MS-CheckEventlog-System
Description = NRPE_Eventlog_System
$ARG1$ = CheckEventLog -a unique=1 file=system
$ARG2$ = "syntax=System Event Log %severity%: Source=%source%: Event ID=%id% Message=%message%"
$ARG3$ = "filter=generated gt -10m AND severity IN ('error', 'critical')
$ARG4$ = AND (id NOT IN (1,3,4,5,8,9,10,11,12,15,17,18,19,27,37,39,41,50,54,56,137,1030,1041,1060,1066,1069,1071,1111,1196,3621,4192,4224,4243,4307,5722,5723,5805,6008))
$ARG5$ = AND (id NOT IN (36888) OR source NOT IN ('Schannel')) AND (id NOT IN (36887) OR source NOT IN ('Schannel'))
$ARG6$ = AND (id NOT IN (36874) OR source NOT IN ('Schannel')) AND (id NOT IN (36870) OR source NOT IN ('Schannel')) AND (id NOT IN (36871) OR source NOT IN ('Schannel'))
$ARG7$ = AND (id NOT IN (7030) OR source NOT IN ('ServiceControlManager'))"
$ARG8$ = MaxWarn=1 MaxCrit=1
Config Name = svc-NRPE-MS-CheckEventlog-Application
Description = NRPE_Eventlog_Application
$ARG1$ = CheckEventLog -a unique=1 file=application
$ARG2$ = "syntax=App Event Log %severity%: Source=%source%: Event ID=%id% Message=%message%"
$ARG3$ = "filter=generated gt -10m AND severity IN ('error')
$ARG4$ = AND (id NOT IN (1,3,10,12,13,23,26,33,37,38,58,67,101,103,104,107,108,110,112,274,502,511,1000,1002,1004,1005,1009,1010,1026,1027,1053,1054,1085,1101,1107,1116,1301,1325,1334,1373,1500,1502,1504,1508,1511,1515,1521,1533))
$ARG5$ = AND (id NOT IN (1509) OR source NOT IN ('Userenv')) AND (id NOT IN (1055) OR source NOT IN ('Userenv')) AND (id NOT IN (1030) OR source NOT IN ('Userenv')) AND (id NOT IN (1006) OR source NOT IN ('Userenv'))
$ARG6$ = AND (id NOT IN (12292) OR source NOT IN ('VSS'))
$ARG7$ = AND (source NOT IN ('Microsoft-SharePoint Products-SharePoint Foundation')) AND (source NOT IN ('Microsoft-Windows-Perflib'))"
$ARG8$ = MaxWarn=10 MaxCrit=20
Disclaimer: Internet research provided me most of the information so if anything looks familiar - Thanks! Maybe I got it from you.
Steve B
