geoip conflict
Re: geoip conflict
ok ill give it a shot
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: geoip conflict
Keep us posted. One other thing too - I was able to get similar results when the geoip lines were added:
In my case it was failing because the dat file didn't exist. The database line isn't necessary so it may be worth testing without this part of the config and/or make sure that /usr/share/GeoIP/GeoLiteCity.dat exists and has write access set.
geoip {
database => "/usr/share/GeoIP/GeoLiteCity.dat"
source => "IPAddress"
}As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Re: geoip conflict
how do I change the field IP to Ipaddress.
that database exists ion the servers, we are using so maybe it will work if I change the field.
The real problem here is that I am clueless when it comes to creating filters. If you guys would be kind enough to answer a few questions for me, it will go a long way towards me being able tyo create and troubleshoot filters like this myself. STOP LAUGHING! i know ya'll are laughing....
so here goes:
first, looking closely at this filter I see that it is listed with with one difference:
line 1
Line 2
Second, I know that Scott must be correct when he said :
my question is whats the difference between the two symbols? and why would it bomb out when I use the suggested correction Scott gave me, but work when I used { instead of the ]?
And third using the following as an example:
what does each term in that line do?
Thanks guys!
so here goes:
match => { "message" => "result=\"%{WORD:result}\" ip=\"%{IP:IP}\" action=\"%{WORD:action}\" params=\"Username: %{USER:params}\" user=\"%{USER:user}\" tenant=\"%{WORD:tenant}\""}
match => { "message" => "result=\"%{WORD:result}\" ip=\"%{IP:IP}\" action=\"%{WORD:action}\" params=\"Username=%{USER:params}\" user=\"%{USER:user}\" tenant=\"%{WORD:tenant}\""}Code: Select all
"Username: %{USER:params}Code: Select all
"Username=%{USER:params}'You were putting your match in { instead of [
result=\"%{WORD:result}Thanks guys!
Proudly running:
Nagios Fusion
Nagios Fusion
swolf
Re: geoip conflict
If you're trying to change one incoming field to another, I would just create another filter. So if the log is coming in with 'IP' as the field, we can do:benhank wrote:how do I change the field IP to Ipaddress.
mutate {
replace => { "Ipaddress" => "%{IP}" }
Make sure this is happening before you use geoip.
In this case, the difference is just matching the literal text of the log line. If you have a log format where you use a colon, likeso here goes:
first, looking closely at this filter I see that it is listed with with one difference:line 1Code: Select all
match => { "message" => "result=\"%{WORD:result}\" ip=\"%{IP:IP}\" action=\"%{WORD:action}\" params=\"Username: %{USER:params}\" user=\"%{USER:user}\" tenant=\"%{WORD:tenant}\""} match => { "message" => "result=\"%{WORD:result}\" ip=\"%{IP:IP}\" action=\"%{WORD:action}\" params=\"Username=%{USER:params}\" user=\"%{USER:user}\" tenant=\"%{WORD:tenant}\""}Line 2Code: Select all
result: "okay" IP: "127.0.0.1" action: "something"The difference here is that {} is referring to a logstash hash (which other languages call a 'map', 'dictionary', 'object', or 'associative array'), where [] is referring to an array (which other languages call a 'list' or 'vector'). Hashes have a list of keys pointing to values, and arrays are lists of just values.Second, I know that Scott must be correct when he said :'You were putting your match in { instead of [
I actually disagree with Scott here about changing {} to [] in the grok/match filters. If we look at the documentation then your original lines were correct. You can change the "message" in match to be an array, but not the match itself.
I would read that asAnd third using the following as an example:what does each term in that line do?Code: Select all
match the literal characters result="
match according to the 'WORD' pattern, store it in the field 'result'
I'll also point out that this is a weird use of %{}. Most of the time, %{} is used to reference a particular field. For instance, I can do
exec {
command => "bash /path/to/do/something.sh %{IP}"
Let us know if that all made sense, or if there are other questions.
Re: geoip conflict
You can save the IP to a field called Ipaddress with:
ip=\"%{IP:Ipaddress}
The different between line 1 and line 2 is the extra space and colon versus equal sign. This it to account for differences in logs where the log line may contain:
Username: jdoe
vs
Username=jdoe
The lines could be made better with some regex to account for both in a single pattern:
match => [ "message" => "result=\"%{WORD:result}\" ip=\"%{IP:IP}\" action=\"%{WORD:action}\" params=\"Username((: ){1})*((=){1})*%{USER:params}\" user=\"%{USER:user}\" tenant=\"%{WORD:tenant}\""]
Using [ vs } is a matter of what exactly you're try to do. This for example:
tells Logstash to take the message field and try to match it against the pattern. And:
tells Logstash to try and match the event(typically the contents of the messages field) against a list of patterns.
this searches for the string "result=" followed by a word that is then stored in a field called "result"
Grok and logstash configs can be ...fun... and can take a moment to get used to. For more examples I would check out:
https://support.nagios.com/kb/article/n ... ew-98.html
https://assets.nagios.com/downloads/nag ... ilters.pdf
Username: jdoe
vs
Username=jdoe
grok {
match => { "message" => "patternpatternpattern..."}
}Code: Select all
grok {
match => ["patternpatternpattern1...","patternpatternpattern2..."]
}Code: Select all
result=\"%{WORD:result}Grok and logstash configs can be ...fun... and can take a moment to get used to. For more examples I would check out:
Re: geoip conflict
THANKS GUYS!
Thanks to everyone who pitched in on this! Im still working on it and will keep you all updated!
Proudly running:
Nagios Fusion
Nagios Fusion
Re: geoip conflict
Sound good!
Re: geoip conflict
this allows me to apply the config and seems to parse the data correctly, I think I have to wait for someone to connect with an external ip in order to get the geoip data, but looking good so far:
if [host] == '172.30.100.226' {
grok {
geoip {
source => "IP"
Proudly running:
Nagios Fusion
Nagios Fusion
Re: geoip conflict
Glad to hear!
Re: geoip conflict
i have another question.
is there a way to force my newly created filter to work on logfiles created before I implemented the newly created filter?
That is If I create a new filter today, I want it to work on logfiles that were sent to NLS from say a month ago.
Proudly running:
Nagios Fusion
Nagios Fusion
