configurations could not be verified
Re: configurations could not be verified
ls -al /usr/local/nagioslogserver/logstash/etc/conf.d/
drwxrwxr-x. 2 nagios nagios 77 Mar 1 01:18 .
drwxrwxr-x. 3 nagios nagios 20 Nov 21 16:14 ..
-rw-rw-r-- 1 nagios nagios 355 Mar 1 02:39 000_inputs.conf
-rw-rw-r-- 1 nagios nagios 318 Mar 1 02:39 500_filters.conf
-rw-rw-r-- 1 nagios nagios 401 Mar 1 02:39 999_outputs.conf
cat /usr/local/nagioslogserver/logstash/etc/conf.d/*
# Logstash Configuration File
# Dynamically created by Nagios Log Server
# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
# Created Fri, 01 Mar 2019 02:39:32 +0800
# Global inputs
input {
tcp {
type => 'syslog'
port => 5544
udp {
type => 'syslog'
port => 514
# Local inputs
# Global filters
filter {
dns {
reverse => ["host"]
action => ["append"]
add_tag => ["dns"]
# Local filters
# Required output for Nagios Log Server
output {
elasticsearch {
hosts => ['localhost']
document_type => '%{type}'
workers => 4
# Global outputs
output {
# Local outputs
/usr/local/nagioslogserver/logstash/bin/logstash -t /usr/local/nagioslogserver/logstash/etc/conf.d/*.conf
Configuration OK
# Global inputs
input {
tcp {
type => 'syslog'
port => 5544
udp {
type => 'syslog'
port => 514
# Local inputs
# Global filters
filter {
dns {
reverse => ["host"]
add_tag => ["dns"]
# Local filters
output {
elasticsearch {
workers => 4
# Global outputs
output {
# Local outputs
Configuration OK
Hmm, the configuration looks like it was written and is valid.
Are you still seeing a verification error?
Still, the nls2 is offline.
It looks like this instance hasn't checked in the last 5 minutes.
Normally this means it is not online or elasticsearch is not running.
but elasticsearch is running,
● elasticsearch.service - LSB: This service manages the elasticsearch daemon
Loaded: loaded (/etc/rc.d/init.d/elasticsearch; bad; vendor preset: disabled)
Active: active (running) since Mon 2019-03-04 20:21:09 +08; 3h 29min ago
Docs: man:systemd-sysv-generator(8)
Process: 4701 ExecStart=/etc/rc.d/init.d/elasticsearch start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/elasticsearch.service
└─4807 /bin/java -Xms16006m -Xmx16006m -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkS...
Thank you
Luke.
Thank you
Luke.
Could you run the following on both nodes?
Also, could this behavior have started after changing interfaces per your other thread?
https://support.nagios.com/forum/viewto ... 37&t=52793
curl -XGET 'http://localhost:9200/_cluster/health?pretty=true'https://support.nagios.com/forum/viewto ... 37&t=52793
in NLS1,
"cluster_name" : "29f99764-1be6-4c0c-9113-b87d54d16034",
"status" : "green",
"timed_out" : false,
"number_of_nodes" : 2,
"number_of_data_nodes" : 2,
"active_primary_shards" : 182,
"active_shards" : 364,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 0,
"delayed_unassigned_shards" : 0,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0
in NLS2,
"status" : "green",
and the other thread in a different nls cluster.
Thank you
Luke.
in NLS1,
"status" : "green",
in NLS2,
"status" : "green",
Thank you
Luke.
One more command to run on each
What I'm looking for is what is in the "host" field
Then we want to make sure you can access that host from your computer (i.e. can your workstation resolve what is in the host field)
curl -XGET 'http://localhost:9200/_nodes?pretty=true'Then we want to make sure you can access that host from your computer (i.e. can your workstation resolve what is in the host field)
From NLS1,
"cluster_name" : "<Cluster_ID>",
"nodes" : {
"DIMoy91QQiC8onRmkmOjKQ" : {
"name" : "3cffd020-3e68-4e00-90f0-210ed2d48438",
"transport_address" : "inet[/<logs_nls2_ip>:9300]",
"host" : "<node_nls2>",
"ip" : "<nls2_operation_ip>",
"version" : "1.7.6",
"build" : "c730b59",
"http_address" : "inet[localhost/127.0.0.1:9200]",
"attributes" : {
"max_local_storage_nodes" : "1"
"settings" : {
"pidfile" : "/var/run/elasticsearch/elasticsearch.pid",
"path" : {
"conf" : "/usr/local/nagioslogserver/elasticsearch/config",
"data" : "/nagios/data",
"logs" : "/var/log/elasticsearch",
"work" : "/usr/local/nagioslogserver/tmp/elasticsearch",
"home" : "/usr/local/nagioslogserver/elasticsearch",
"repo" : "/"
"cluster" : {
"name" : "<Cluster_ID>"
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"hosts.0" : "localhost",
"hosts" : "localhost,<<logs_nls1_ip>,<logs_nls2_ip>,<logs_nls_vip>"
"http" : {
"host" : "localhost",
"max_content_length" : "1024mb"
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"ignore_system_properties" : "true"
"os" : {
"refresh_interval_in_millis" : 1000,
"available_processors" : 4,
"cpu" : {
"vendor" : "Intel",
"model" : "Core Processor (Skylake)",
"mhz" : 1999,
"total_cores" : 4,
"total_sockets" : 4,
"cores_per_socket" : 1,
"cache_size_in_bytes" : 4096
"mem" : {
"total_in_bytes" : 33567166464
"swap" : {
"total_in_bytes" : 68715278336
"process" : {
"id" : 4807,
"max_file_descriptors" : 65535,
"mlockall" : true
"jvm" : {
"pid" : 4807,
"version" : "1.8.0_191",
"vm_name" : "OpenJDK 64-Bit Server VM",
"vm_version" : "25.191-b12",
"vm_vendor" : "Oracle Corporation",
"start_time_in_millis" : 1551702069197,
"mem" : {
"heap_init_in_bytes" : 16783507456,
"heap_max_in_bytes" : 16748642304,
"non_heap_init_in_bytes" : 2555904,
"non_heap_max_in_bytes" : 0,
"direct_max_in_bytes" : 16748642304
"gc_collectors" : [ "ParNew", "ConcurrentMarkSweep" ],
"memory_pools" : [ "Code Cache", "Metaspace", "Compressed Class Space", "Par Eden Space", "Par Survivor Space", "CMS Old Gen" ]
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"fetch_shard_started" : {
"type" : "scaling",
"min" : 1,
"max" : 8,
"keep_alive" : "5m",
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "200"
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"keep_alive" : "30s",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"fetch_shard_store" : {
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"refresh_interval_in_millis" : 5000,
"primary_interface" : {
"address" : "<logs_nls2_ip>",
"name" : "eth1",
"mac_address" : "52:54:00:4C:41:10"
"transport" : {
"bound_address" : "inet[/0:0:0:0:0:0:0:0%0:9300]",
"publish_address" : "inet[/<logs_nls2_ip>:9300]",
"profiles" : { }
"http" : {
"bound_address" : "inet[/127.0.0.1:9200]",
"publish_address" : "inet[/127.0.0.1:9200]",
"max_content_length_in_bytes" : 1073741824
"plugins" : [ {
"name" : "knapsack-1.7.3.0-d0ea246",
"version" : "1.7.3.0",
"description" : "Knapsack plugin for import/export",
"jvm" : true,
"site" : false
"VxMeGhgzSeSwmEXxK1RbAg" : {
"name" : "12c3bc39-1cf0-4dfd-a2c8-d9ec25fd25e8",
"transport_address" : "inet[/<logs_nls1_ip>:9300]",
"host" : "pl-pd-nls1",
"ip" : "<nls1_operation_ip>",
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"hosts" : "localhost,<logs_nls1_ip>,<logs_nls2_ip>,<logs_nls_vip>"
"http" : {
"max_content_length" : "1024M"
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 2000,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4780,
"mlockall" : true
"jvm" : {
"pid" : 4780,
"start_time_in_millis" : 1551702378044,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"address" : "<logs_nls1_ip>",
"name" : "eth1",
"mac_address" : "52:54:00:07:58:36"
"transport" : {
"bound_address" : "inet[/0:0:0:0:0:0:0:0:9300]",
"publish_address" : "inet[/<logs_nls1_ip>:9300]",
"profiles" : { }
"http" : {
"publish_address" : "inet[localhost/127.0.0.1:9200]",
"plugins" : [ {
"jvm" : true,
"site" : false
From NLS2,
"nodes" : {
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 1999,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4807,
"mlockall" : true
"jvm" : {
"pid" : 4807,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 2000,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4780,
"mlockall" : true
"jvm" : {
"pid" : 4780,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
I am able to ping, hostnames and IP of NLS1 and 2 from the workstation.All the NLS IPs and Hostnames are defined in the workstation's /etc/hosts file.
Luke.
From NLS1,
"nodes" : {
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 1999,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4807,
"mlockall" : true
"jvm" : {
"pid" : 4807,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 2000,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4780,
"mlockall" : true
"jvm" : {
"pid" : 4780,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
From NLS2,
"nodes" : {
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 1999,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4807,
"mlockall" : true
"jvm" : {
"pid" : 4807,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
"attributes" : {
"settings" : {
"path" : {
"repo" : "/"
"cluster" : {
"node" : {
"discovery" : {
"zen" : {
"ping" : {
"multicast" : {
"enabled" : "false"
"unicast" : {
"http" : {
"client" : {
"type" : "node"
"bootstrap" : {
"mlockall" : "true"
"transport" : {
"tcp" : {
"compress" : "true"
"config" : {
"os" : {
"cpu" : {
"vendor" : "Intel",
"mhz" : 2000,
"total_cores" : 4,
"mem" : {
"swap" : {
"process" : {
"id" : 4780,
"mlockall" : true
"jvm" : {
"pid" : 4780,
"mem" : {
"thread_pool" : {
"percolate" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"listener" : {
"type" : "fixed",
"min" : 2,
"max" : 2,
"queue_size" : -1
"index" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"refresh" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"suggest" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"generic" : {
"type" : "cached",
"queue_size" : -1
"warmer" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"search" : {
"type" : "fixed",
"min" : 7,
"max" : 7,
"queue_size" : "1k"
"flush" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"optimize" : {
"type" : "fixed",
"min" : 1,
"max" : 1,
"queue_size" : -1
"type" : "scaling",
"min" : 1,
"max" : 8,
"queue_size" : -1
"management" : {
"type" : "scaling",
"min" : 1,
"max" : 5,
"queue_size" : -1
"get" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "1k"
"merge" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"bulk" : {
"type" : "fixed",
"min" : 4,
"max" : 4,
"queue_size" : "50"
"snapshot" : {
"type" : "scaling",
"min" : 1,
"max" : 2,
"queue_size" : -1
"network" : {
"name" : "eth1",
"transport" : {
"profiles" : { }
"http" : {
"plugins" : [ {
"jvm" : true,
"site" : false
Luke.
This is really bizarre as they can both see each other.
Are you a licensed customer? I'd like to setup a remote session to take a look at the system
Yes, all the NLS clusters are licensed. Let me check with the customer if they allowed remote access.
Regards
Luke.
Regards
Luke.
Sounds good, let me knowlukedevon wrote:Yes, all the NLS clusters are licensed. Let me check with the customer if they allowed remote access.
Regards
Luke.
