Dear Ssax,
Could you please indicate the configuration so that the notifications arrive according to the escalation ... every 30 minutes to the security area when the host is inactive and every 60 escalation notifications to the other areas.
Greetings.
Query scaling nagios Core
Re: Query scaling nagios Core
These were already posted and should do what you want:
This one notifies seguridad every 30 minutes from the first notification onward:
This one notifies infraestructura and soporte every 60 minutes from the 2nd notification onward (I used the 2nd notification because the notification_interval on the service is set to 30 (so 30*2=60 for the first notification)):
One thing you need to remember is this:
Because the notifications only occur when a check is in process, it matters what you set your check_interval and notification_interval to. For example, assuming these settings for your host:
The following would occur:
- Assume each of these is a Host Down result
+00:00 - Check #1 - Initial Host Down - (1 of 3 max_check_attempts) (SOFT state) (Notification: No)
+00:01 - Check #2 - retry_interval (one minute later), Host Down 2 of 3, SOFT state, (Notification: No)
+00:02 - Check #3 - Escalation 1 hit - retry_interval (one minute later), Host Down 3 of 3, HARD state, notification sent to seguridad - (Notification 1 - seguridad, 2 minutes since first problem detected)
+00:04 - Check #4 - falls back to check_interval of 2 minutes, Host Down, HARD state, notification should try to be sent but... the first notification was sent less that notification_interval (30) ago so no notification will be sent
+00:06 - Check #5 - falls back to check_interval of 2 minutes - (Notification: No)
+00:08 - Check #6 - falls back to check_interval of 2 minutes - (Notification: No)
+00:10 - Check #7 - falls back to check_interval of 2 minutes - (Notification: No)
+00:12 - Check #8 - falls back to check_interval of 2 minutes - (Notification: No)
+00:14 - Check #9 - falls back to check_interval of 2 minutes - (Notification: No)
+00:16 - Check #10 - falls back to check_interval of 2 minutes - (Notification: No)
+00:18 - Check #11 - falls back to check_interval of 2 minutes - (Notification: No)
+00:20 - Check #12 - falls back to check_interval of 2 minutes - (Notification: No)
+00:22 - Check #13 - falls back to check_interval of 2 minutes - (Notification: No)
+00:24 - Check #14 - falls back to check_interval of 2 minutes - (Notification: No)
+00:28 - Check #15 - falls back to check_interval of 2 minutes - (Notification: No)
+00:30 - Check #16 - Escalation 1 (again) - If this really fell on 00:30 exactly you would get the second notification to seguridad but if the scheduler put it a little before then you would not have exceeded the 30 minute notification_interval and the notification would be sent on the next check at +00:32. - (Notification 2 - seguridad)
+00:32 - Check #17 - falls back to check_interval of 2 minutes - (Notification: No)
+00:14 - Check #18 - falls back to check_interval of 2 minutes - (Notification: No)
+00:60 - Escalation 1 (again) | Escalation 2 (1st) - (Notification 3 - seguridad && Notification 1 for infraestructura AND soporte)
define hostescalation {
hostgroup_name FW
first_notification 1
last_notification 0
notification_interval 30
escalation_period 24x7
escalation_options d,r
contact_groups seguridad
}Code: Select all
hostgroup_name FW
first_notification 2
last_notification 0
notification_interval 60
contact_groups infraestructura,soporte
}Because the notifications only occur when a check is in process, it matters what you set your check_interval and notification_interval to. For example, assuming these settings for your host:
define host {
use linux-server,host-pnp
host_name MGMT
alias MGMT
address X.X.X.X
check_interval 2
check_period 24x7
max_check_attempts 3
retry_interval 1
notifications_enabled 1
notification_period 24x7
notification_options d,u,r,s
}- Assume each of these is a Host Down result
