Email Notifications Don't Work
gpanou
Re: Email Notifications Don't Work
Post by gpanou »
Update:
I did a system upgrade to the latest version, and as a result the file I altered got overwritten and the issue came back.
At some point nagios xi run out of memory leading to a crash during a core config apply, in the monitoring engine status section (if i remember well) the interface suggested a db repair after that. The message was related to notifications.
We run a DB repair as suggested in : https://assets.nagios.com/downloads/nag ... tabase.pdf
The results of the process are in the attachment.
Can we please look into it, we need a permanent fix.
Thank you
I noticed after making the repair you were running the wrong service to restart the Db
Should be
systemctl restart mariadb
gpanou
Post by gpanou »
Notifications seem to be working properly after the repair.
If anything changes, e.g. on a following software upgrade I will let you know.
gpanou wrote:Notifications seem to be working properly after the repair.
Sounds good!
