Error in a simple config on Nagios Core 4.4.3
Re: Error in a simple config on Nagios Core 4.4.3
I missed it from before but the verify has to be the nagios.cfg file. Run this to verify the Nagios configuration files.
That was causing the Null error.
mpedros
Post by mpedros »
Now I do not get an error because the file "oficina.cfg" is all commented. As soon as I unplug it, the error reappears.
root@debianNC:/usr/local/nagios/etc/objects# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 8 services.
        Checked 1 hosts.
        Checked 1 host groups.
        Checked 0 service groups.
        Checked 1 contacts.
        Checked 1 contact groups.
        Checked 24 commands.
        Checked 5 time periods.
        Checked 0 host escalations.
        Checked 1 hosts
        Checked 0 host dependencies
        Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
root@debianNC:/usr/local/nagios/etc/objects# cat oficina.cfg
#define host{
#        use generic-networking-device
#        host_name FIREWALL
#        alias FIREWALL
#        address 192.168.6.1
#define service{
#        use generic-service
#        service_description Ping
#        check_command check_ping!60.0,5%!100.0,10%
Martin Pedros
I would delete that file from the system and there is something wrong with it.
Copy the localhost.cfg file and use that as the template for the new "oficina.cfg" file . Leave the settings in the file but update the name and IP address and see if that works.
mpedros
Post by mpedros »
Hi:
I followed the steps you said to me using the localhost.cfg file as template and it gives me an eeror on line 21, just where the host definition starts, I attached the step by step to verify what I did:
root@debianNC:/usr/local/nagios/etc/objects# ls
baxo.cfg      contacts.cfg   oficina.cfg  switch.cfg     timeperiods.cfg
commands.cfg  localhost.cfg  printer.cfg  templates.cfg  windows.cfg
root@debianNC:/usr/local/nagios/etc/objects# cp oficina.cfg BKPoficina22042019.cfg
root@debianNC:/usr/local/nagios/etc/objects# rm oficina.cfg
root@debianNC:/usr/local/nagios/etc/objects# cp localhost.cfg oficina.cfg
root@debianNC:/usr/local/nagios/etc/objects# nano oficina.cfg
# LOCALHOST.CFG - SAMPLE OBJECT CONFIG FILE FOR MONITORING THIS MACHINE
# NOTE: This config file is intended to serve as an *extremely* simple
#       example of how you can create configuration entries to monitor
#       the local (Linux) machine.
# HOST DEFINITION
# Define a host for the local machine
define host {
    use                     linux-server            ; Name of host template to use
                                                    ; This host definition will inherit all variables that are defined
                                                    ; in (or inherited by) the linux-server host template definition.
    host_name               firewall
    alias                   firewall
    address                 192.168.6.1
# SERVICE DEFINITIONS
# Define a service to "ping" the local machine
    use                     local-service           ; Name of service template to use
    host_name               firewall
    service_description     PING
    check_command           check_ping!100.0,20%!500.0,60%
root@debianNC:/usr/local/nagios/etc/objects# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/objects/oficina.cfg
Nagios Core 4.4.3
License: GPL
Error in configuration file '/usr/local/nagios/etc/objects/oficina.cfg' - Line 21 (NULL value)
   Error processing main config file!
Nagios Core 4.4.3
License: GPL
Checking objects...
        Checked 9 services.
        Checked 2 hosts.
        Checked 1 contacts.
        Checked 2 hosts
Total Warnings: 0
Total Errors:   0
Martin Pedros
The reason you are getting the error, is because you are using the wrong file in the verification command.
You should never use a host file in the verify command.
Only run this which will verify the mail config file and all of the config files defined in the main nagios.cfg file.
https://assets.nagios.com/downloads/nag ... onfig.html
mpedros
Post by mpedros »
Hi Tgriep:
I apologize for my error, looking for how to solve the problem in some place I read that could be verified with the name of the file that gives error as well. It is already working so we can consider this ticket closed.
Thank you again for the great help!
Martin Pedros
OK. I'll close and lock the post for you. But feel free to open a new post in the future for any new questions.
