Just to be clear, the only way to programmatically extract the same results as the XI availability report is to use the curl and chrome developer approach to identify the exact parameters?
Thanks.
Obtaining Availability Report Data Via API
npolovenko
- Support Tech
Re: Obtaining Availability Report Data Via API
@awilson, From the API reports you can get the availability data for a host, service, hostgroup or a servicegroup and in the output you'll see total_time_down and time_down_scheduled. If you deduct total_time_down - time_down_scheduled you'll get the availability time without scheduled downtime.
That's the only way I could think of.
Thank you. Do you know which release added the hostavailability and serviceavailability endpoints?
Thanks!
Thanks!
npolovenko
- Support Tech
@awilson, We added these API endpoints in XI 5.5.
Thanks. You can close this. I appreciate the help.
