check_http
nickanderson1982
Re: check_http
Post by nickanderson1982 »
Opening up port 443 worked. All test checks are working now. So how would I write up the cfg file. You gave me two examples, which one would work for 443?
nickanderson1982
Re: check_http
I didn't realize it was the same cfg file, I just compared. Do I need to make any adjustments to make it set for 443?
npolovenko
Re: check_http
Post by npolovenko »
@nickanderson1982, Make sure this command is working from the command line first:
/usr/local/nagios/libexec/check_http -H xxx.xxxx.com -f follow -u "/api/api.asmx"
And if it does work, you don't need to make adjustments to the cfg.
Optionally, you can include -p 443 in the command:
check_service_http! -f ok -p 443  -u '/api/api.asmx'
nickanderson1982
Re: check_http
I added everything in the cfg file and then added to the nagios.cfg file.
Under Hosts on the UI it shows the host as up, but when you go to the Services it has the URL Status / Critical / HTTP CRITICAL - No Data recieved from host.
How do I correct the Services portion?
npolovenko
Re: check_http
@nickanderson1982, Please download the following file from the Core server and PM it to me on the forum:
/usr/local/nagios/var/objects.cache
nickanderson1982
Re: check_http
How do I make the reply private? Or do I have to just PM the file?
npolovenko
Re: check_http
@nickanderson1982, You'll just need to PM the file. After you send it, post a message here to bring this thread up to the support queue.
nickanderson1982
Re: check_http
I just PM the file to you.
Took a minute because you can't post so soon after your last.
npolovenko
Re: check_http
@nickanderson1982, I sent you the command to run in personal message. Let me know if that exact command works from the command line?
nickanderson1982
Re: check_http
I just private messaged you my response
