custom plugin: CHECK_NRPE: Receive header underflow - only 0
anilgupta
Re: custom plugin: CHECK_NRPE: Receive header underflow - on
Post by anilgupta »
@benjaminsmith,
Thanks for the support.
I understood the issue. Client is not accepting the parameters. I tried to change "dont_blame_nrpe=1" in nrpe.cfg, but still not working.
I will proceed with hardcoding the value in nrpe.cfg.
benjaminsmith
Post by benjaminsmith »
Hi @anilgupta,
Did you update the command definition as well in the nrpe.cfg file?
command[check_oim]=/usr/local/nagios/libexec/check_oim $ARG1$ $ARG2$
Note that if you want to pass arguments to nrpe, this must be specified as a configuration option when it is compiled. If it was installed without this option, you'll need to hardcode the values in the command definition.
See: NRPE - How To Install NRPE v3 From Source
