Check drives size displays too much information
Re: Check drives size displays too much information
You could exclude this drive from your check for the time being, until you figure out what is causing the issue. What kind of drive is it? We would need to do some more digging into this. If we could recreate the issue in-house, maybe we would be able to come up with a solution, or at least point you to the right direction.
Frédéric GRANAT
Hi
=> Thanks, done
Could you please tell me what kind of information do you need ?
=> Thanks, done
Is it a fixed drive, CDROM, network share, etc.Frédéric GRANAT wrote:What kind of drive is it?
Frédéric GRANAT
It's a ntfs partition.
If you look at it's properties is the D: drive extremely large? Does it show properly the size in Windows?Frédéric GRANAT wrote:Hi,
For some reason Windows is returning a negative number when querying the size
Frédéric GRANAT
Nothing abnormal in the properties
scottwilkerson wrote:If you look at it's properties is the D: drive extremely large?
Frédéric GRANAT
No,
Disk is not large
Disk is not large
Try running the command against the D: drive to see that sort of errors are generated. The command below has the debug option so hopefully it will show something.
/usr/local/nagios/libexec/check_wmi_plus.pl -H xxxxxxxxxxx -u xxxxxxxxxxx -p xxxxxxxxxxxxx -m checkdrivesize -a 'D:' -w _FreeGB=10: -c _FreeGB=5: --extrawmicarg "--debuglevel=4" -d Be sure to check out our Knowledgebase for helpful articles and solutions!
Frédéric GRANAT
Here's the output :
Here's the output :
[[email protected] ~]# /usr/local/nagios/libexec/check_wmi_plus.pl -H xxxxx -u xxxxxxx -p xxxxxxx-m checkdrivesize -a 'C:|D:|E:|F:|G:|Q:|H:|I:|L:|M:|N:|R:' -w _FreeGB=10: -c _FreeGB=5: --extrawmicarg "--debuglevel=4" -d
Complex Format:_UsedSpace,#B,Used,, ,,
Last edited by Frédéric GRANAT on Tue Jun 04, 2019 10:23 am, edited 2 times in total.
