Command works on CLI but not in SNMPTT event handler
swolf
Re: Command works on CLI but not in SNMPTT event handler
Post by swolf »
Your guess sounds pretty reasonable to me.
In the name of due diligence, I have to ask you a few more questions:
Is there anything interesting happening on your XI filesystem? Any soft links/disk mounts that might have strange permissions?
What linux distribution is your server running on?
Can you verify the permissions on your scripts?
ls -l /usr/local/nagiosxi/scripts/nxti.php
ls -l /usr/local/nagios/libexec/submit_passive_service.sh
groups snmptt
When you send a trap, are you seeing any errors in your other logs? I'd at least check /var/log/messages and possibly also your apache error log (path varies by distro, but on CentOS it's /var/log/httpd/error_log).
Lastly, and this is optional depending on your team's security restrictions/personal security preferences, but would you be able to try giving snmptt a shell and running the SNMPTT EXEC commands as them?
sed -Ei 's#snmptt(.*)/sbin/nologin#snmptt\1/bin/bash#' /etc/passwd
su snmptt
and when finished:
sed -Ei 's#snmptt(.*)/bin/bash#snmptt\1/sbin/nologin#' /etc/passwd
Hopefully we'll either see the issue or be able to re-create a bug with this information
gavnor
Post by gavnor »
Debian GNU/Linux 9 (stretch) running as a VM on a Xen Hypervisor. The file system is ext4 on an LVM.
-rwxr-xr-x 1 nagios nagios 1325 Apr 25 15:47 /usr/local/nagiosxi/scripts/nxti.php
-rwxr-xr-x 1 www-data nagcmd 1185 May  7 12:45 /usr/local/nagios/libexec/submit_passive_service.sh
snmptt : snmptt nagios nagcmd
These are the only logs from /var/log/messages that I'm unsure of and occurred around the time of the trap.
May  7 14:30:20 nagiosxi ndo2db: Trimming timedevents.
May  7 14:30:20 nagiosxi ndo2db: Trimming systemcommands.
May  7 14:30:20 nagiosxi ndo2db: Trimming servicechecks.
May  7 14:30:20 nagiosxi ndo2db: Trimming hostchecks.
May  7 14:30:20 nagiosxi ndo2db: Trimming eventhandlers.
Nothing recorded in /var/log/apache2/error.log at the time of the trap.
Running as snmptt and executing the command via CLI the passive check was received and the service updated.
swolf
Post by swolf »
Those messages look normal to me. I'm setting up a debian system to see if I can re-create your issue. I'll update this thread again soon, hopefully with a solution.
EDIT: I am able to reproduce the issue on my system
swolf
Post by swolf »
Thought I'd give a proper update here:
There were a couple of different issues that I found.
First, I found that the /usr/local/nagiosxi/scripts/nxti.php script has a bug. This is fixed in the attached script, and will at least allow the script to work from the CLI. Note that you'll need to change the file extension back to .php
nxti.txt
Second, there are some strange permissions set by default in debian, which prevent the apache user from sending an SNMP trap. These commands fixed it for me:
chmod g+w /var/lib/snmp
usermod -a -G Debian-snmp www-data
My hope is that these two changes will at least get your service status changes working. I also found a third issue, which may be a bug in snmptt, and which is still preventing the received traps table from working properly. If you don't care about the details, feel free to skip to the very bottom of this post:
I manually changed the EXEC command to the following:
php /usr/local/nagiosxi/scripts/nxti.php --event_name="$N"  --event_oid="$i" --numeric_oid="$o" --symbolic_oid="$O" --community="$C" --trap_hostname="$R" --trap_ip="$aR" --agent_hostname="$A" --agent_ip="$aA" --category="$c" --severity="$s" --uptime="$T" --datetime="$x $X" --unixtime="$@" --bindings="$+*" >> /usr/local/nagiosxi/var/NXTI_Write_Test
Running snmptt in debug mode, I got the following command:
EXEC line(s):
EXEC command:php /usr/local/nagiosxi/scripts/nxti.php --event_name="NXTI_Event_1"  --event_oid=".1.3.6.1.4.1.8072.2.3.0.1" --numeric_oid=".1.3.6.1.4.1.8072.2.3.0.1" --symbolic_oid="netSnmpExampleHeartbeatNotification" --community="" --trap_hostname="localhost" --trap_ip="127.0.0.1" --agent_hostname="localhost" --agent_ip="127.0.0.1" --category="NXTI Test Event" --severity="Normal" --uptime="0:19:24:20.02" --datetime="2019-05-08 10:33:05" --unixtime="1557329585" --bindings="netSnmpExampleHeartbeatRate:123456" >> /usr/local/nagiosxi/var/NXTI_Write_Test
snmptt
Warning: require_once(/usr/local/nagiosxi/html/config.inc.php): failed to open stream: Permission denied in /usr/local/nagiosxi/scripts/nxti.php on line 6
Fatal error: require_once(): Failed opening required '/usr/local/nagiosxi/scripts/../html/config.inc.php' (include_path='.:/usr/share/php') in /usr/local/nagiosxi/scripts/nxti.php on line 6
But after giving snmptt a shell, I found that the command worked as expected:
debug: required files and connected to db
/* other debugging output */
Anyways, let me know how those first two changes work out for you, and I'll continue to work at this for a bit, and see if I can get in contact with the original author of snmptt
gavnor
Post by gavnor »
Thank you very much for the update.
I updated the nxti.php file as directed.
I then ran the following:
And also gave snmptt a shell:
usermod -s /bin/bash snmptt
After analyzing the changes to the php command, I appended
but nothing was written.
After making these changes, the trap event still doesn't work correctly. I can now run the php command from the CLI and produce a result in the received traps log but that command doesn't trigger a service status update. I can still run the static submit script from the command line and produce a status update but neither of those commands trigger by the trap receiver.
Please let me know if this is where we are in the troubleshooting or if I'm missing another step somewhere.
swolf
Post by swolf »
gavnor wrote: Please let me know if this is where we are in the troubleshooting
It doesn't necessarily look inconsistent. Here's where I am:
1. the PHP script (nxti.php) now works when run from the CLI, whether as root or as snmptt
As far as I can tell we both have that working
2. The received traps table does not update when a trap is sent
It seems we both have this issue as well
3. The snmp trap should still "fire".
i.e., if you do something like
tail -f /var/log/snmptt/snmptt.log
You should see a new log entry every time you click the 'send test trap' button or run the snmptrap command from your command line.
If #3 matches then our systems are at least the same. If #3 doesn't work, run this and let me know the output:
su www-data
snmptrap -v 2c -c public localhost '' NET-SNMP-EXAMPLES-MIB::netSnmpExampleHeartbeatNotification netSnmpExampleHeartbeatRate i 123456
gavnor
Post by gavnor »
Thank you for clarifying. I believe our results are aligned.
swolf
Post by swolf »
Okay, as a temporary fix, you can make the following changes:
Change the permissions of config.inc.php to be world-readable
chmod 644 /usr/local/nagiosxi/html/config.inc.php
This creates a minor security vulnerability on your system, but as long as you're only using your server to run Nagios XI, you should be okay.
You'll also want to modify /usr/local/nagiosxi/scripts/reset_config_perms.sh, changing line 76 from
/bin/chmod 640 /usr/local/nagiosxi/html/config.inc.php
to
/bin/chmod 644 /usr/local/nagiosxi/html/config.inc.php
in order to avoid having to make this change again later.
We will try to create a more secure solution for this issue, but for now this should allow you to use the application as expected.
Let me know if you have any issues with this or if you have any other questions.
gavnor
Post by gavnor »
I've made the recommended changes and I now see traps logging in the received traps log however services aren't updating.
Passive Service Setup:
Host Name: $aR (IP)
Service Description: LostPowerEvent
Severity: Parse Severity Level ($s)
Service Output: SNMP Trap Received at $@ with variables $+*
Service Definition:
    host_name                <ip>
    service_description      LostPowerEvent
    use                      xiwizard_passive_service
    is_volatile              1
    max_check_attempts       1
    check_interval           1
    retry_interval           1
    check_period             xi_timeperiod_24x7
    notification_interval    60
    notification_period      xi_timeperiod_24x7
    contacts                 nagiosadmin
    stalking_options         n
    _xiwizard                passivecheck
    register                 1
The received traps log shows the events received by my host IP and registered as Critical Severity but my Service Status is still "No check results for service yet..."
Is there something I'm missing or are there more permissions that need adjusted?
swolf
Post by swolf »
My apologies, I missed one thing. We'll also need to add read/write permissions to nagios.cmd to submit passive check results.
chmod 666 /usr/local/nagios/var/rw/nagios.cmd
I imported your service definition and trap definition from page 1 and this worked on my test machine. If there is somehow still an issue, I'd expect the result to at least show up in Admin -> Monitoring Config -> Unconfigured Objects.
