How Does NRPE Calculate Memory
mkeey
Re: How Does NRPE Calculate Memory
Post by mkeey »
Our Linux Admin did some digging and found this article...
https://support.nagios.com/kb/article.php?id=171
NRPE - Linux Cached Memory Not Added to Free Memory Article Number: 171 | Rating: Unrated | Last Updated by tlea on Tue, Feb 9, 2016 at 9:29 PM
-> EDIT ARTICLE <-
Problem Description
In older versions of the Linux NRPE Agent, the memory plugin custom_check_mem did not take into account cached memory as part of the free memory and may create false warning or critical alerts, even though you are NOT low on memory.
Resolving The Problem
In order to fix this, we have updated the custom_check_mem plugin, part of our Linux agent install script by adding an optional flag [-n|--nocache]. Basically, cached memory is added to the free memory when you use the "-n" flag.
Usage:
custom_check_mem [-w|--warning]<percent free> [-c|--critical]<percent free> [-n|--nocache]
If you are downloading a new copy of our Linux agent, the updated custom_check_mem plugin will be included. If you already installed the Linux agent, you can just download the updated custom_check_mem from here. Copy the new script over the old custom_check_mem.
Next we need adjust any services to include the -n argument.
Go to Core Config Manager > Monitoring > Services Find the Memory Usage service and click it On the Common Settings tab modify the $ARG2$ field by adding a -n flag
For example, if you had:
-a '-w 20 -c 10'
Change it to:
-a '-w 20 -c 10 -n'
Question - How can I add this "-n" to all of our Linux memory monitors? We are currently at v5.5.5.
The -n was already in the config for the server you showed
command[check_mem]=/usr/local/nagios/libexec/custom_check_mem -n $ARG1$
It can either be added there or to the service arguments like you mentioned
mkeey wrote:-a '-w 20 -c 10 -n'
but not both
mkeey
Post by mkeey »
Not sure where you're seeing that. Look at the config I posed and memuse is coded...
host_name REMOTESERVERNAME
service_description Memory Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_mem!-a '-w 10 -c 5'
max_check_attempts 24
check_interval 10
retry_interval 5
notification_interval 60
notification_options n
notifications_enabled 0
contacts ENDUSERS
_xiwizard linux-server
register 1
I do not see the "-n". Am I looking in the wrong place?
mkeey
Post by mkeey »
I checked in the XI and I don't see the "-n" in the command. See attached screen print.
mkeey
Post by mkeey »
Tried it thru Config Manager...
mkeey wrote:Not sure where you're seeing that. Look at the config I posed and memuse is coded...
I'm seeing it in the common.cfg you posted here
https://support.nagios.com/forum/viewto ... 90#p282136
mkeey wrote:As requested...
[MYUSER@PROBLEMCHILD]:[/usr/local/nagios/etc/nrpe]# more common.cfg
### GENERIC SERVICES ###
command[check_init_service]=sudo /usr/local/nagios/libexec/check_init_service $A
RG1$
command[check_services]=/usr/local/nagios/libexec/check_services -p $ARG1$
### MISC SYSTEM METRICS ###
#command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10
command[check_users]=/usr/local/nagios/libexec/check_users $ARG1$
command[check_load]=/usr/local/nagios/libexec/check_load $ARG1$
command[check_swap]=/usr/local/nagios/libexec/check_swap $ARG1$
command[check_cpu_stats]=/usr/local/nagios/libexec/check_cpu_stats.sh $ARG1$
### SYSTEM UPDATES ###
command[check_yum]=/usr/local/nagios/libexec/check_yum
command[check_apt]=/usr/local/nagios/libexec/check_apt
### DISK ###
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
command[check_ide_smart]=/usr/local/nagios/libexec/check_ide_smart $ARG1$
### PROCESSES ###
command[check_all_procs]=/usr/local/nagios/libexec/custom_check_procs
command[check_procs]=/usr/local/nagios/libexec/check_procs $ARG1$
### OPEN FILES ###
command[check_open_files]=/usr/local/nagios/libexec/check_open_files.pl $ARG1$
### NETWORK CONNECTIONS ###
command[check_netstat]=/usr/local/nagios/libexec/check_netstat.pl -p $ARG1$ $ARG
2$
mkeey
Post by mkeey »
Talked with our Linux Admin and he seems happy... for now. Please close the case and thanks for your help.
mkeey wrote:Talked with our Linux Admin and he seems happy... for now. Please close the case and thanks for your help.
great!
Locking thread
